A question about using multiSolidBodyMotionSolver/multiMotion in OF v7
Old   October 3, 2021, 15:01
Wink A question about using multiSolidBodyMotionSolver/multiMotion in OF v7
dzs
dntjudme is on a distinguished road
Dear Foamers,
I'm using OF v7 multiSolidBodyMotionSolver for simulating a wind turbine aerodynamics case.
What I want to do is to simulate the wind turbine rotating motion + surge motion simultaneously, I referred to what OpenFOAM wiki suggested in section 2.8 multiMotion: https://openfoamwiki.net/index.php/P...sh#multiMotion
Following what wiki suggested, I setup the dynamicMeshDict as follows, which has been modified slightly in OF v7 style
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolver    //solidBody;
                multiSolidBodyMotionSolver;
solidBodyMotionFunction  multiMotion;
                surgeBox
                    solidBodyMotionFunction  oscillatingLinearMotion;
                    oscillatingLinearMotionCoeffs
                      amplitude     (0.125 0 0);//(0.125 0 0);
                      omega         0.785398; // (rad/s) 0.125 Hz = 0.785398 rad/s
                rotor
                    solidBodyMotionFunction  rotatingMotion;
                    rotatingMotionCoeffs
                      origin          (0 0 2.086);
                      axis            (1 0 0);
                      omega           25.1327;//240; //25.1327 rad/s
The assignment of cellZone "rotor" is done in snappyHexMeshDict, includes cells inside the AMI patch; the "surgeBox" is assigned in topoSet with the following code, the line "box (-9 -7 0) (11 7 4);" covers all cells in the entire computational domain:
        name    surgeBoxSource;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
        name    surgeBox;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set surgeBoxSource;
Then, I ran the moveDynamicMesh command to preview the mesh motion in ParaView, and here is what I got:1png.jpg
Here you can see that the rotation of the cellZone "rotor" is not happening while the surge motion can be properly simulated.
Does anyone know how to correctly tune the multiMotion Coeffs for this case so that the mesh motion can be properly moved with rotating motion + surge motion occurring simultaneously?
Many thanks!
Zs
dntjudme is offline   Reply With Quote
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
