Calculating rather than prescribing solid body motion using immersed boundary method?
Like Tree2Likes
  • 1 Post By courant_numero_uno
Old   September 25, 2019, 19:47
Default Calculating rather than prescribing solid body motion using immersed boundary method?
courant_numero_uno is on a distinguished road
I am using foam-extend-4.0. I have a simulation working using the movingCylinderInChannelIco tutorial, which uses the immersed boundary method. The dynamicMeshDict uses immersedBoundarySolidBodyMotionFvMesh:
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
// dynamicFvMesh   staticFvMesh;
dynamicFvMesh   immersedBoundarySolidBodyMotionFvMesh;
immersedBoundarySolidBodyMotionFvMeshCoeffs
    motionFunctions
        cylinder
//             solidBodyMotionFunction     translation;
//             translationCoeffs
//                 velocity (0.1 0 0);
            solidBodyMotionFunction     linearOscillation;
            linearOscillationCoeffs
                amplitude    (0 0.3 0);
                period       1.5;
However, I would like to calculate the motion of the cylinder rather than define it. Specifically, to simulate vibrations using a spring restraint. For example, I have a dynamicMeshDict using dynamicMotionSolverFvMesh, which works:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
dynamicFvMesh   dynamicMotionSolverFvMesh;
//staticFvMeshCoeffs
motionSolverLibs ( "libsixDoFRigidBodyMotion.so" );
solver          sixDoFRigidBodyMotion;
//diffusivity     quadratic inverseDistance 1 ( cylinder );
sixDoFRigidBodyMotionCoeffs
    patches         ( cylinder );
    innerDistance   0.05;
    outerDistance   0.7;
    centreOfMass    ( 0 0 0 );
    mass            75.362562415;
    g               ( 0 0 -9.8065 );
    momentOfInertia ( 2.7874e+08 5.8901e+08 6.6762e+08 );
    velocity        ( 0 0 0 );
    rho             rhoInf;
    rhoInf          1.225;
    accelerationRelaxation 0.5;
    //accelerationDamping 0.95;
    report          on;
    reportToFile    on;
    solver
        type            Newmark;
    constraints
        onlymoveiny
            sixDoFRigidBodyMotionConstraint     line;
            direction                            (0 1 0);
        norotation
            sixDoFRigidBodyMotionConstraint     orientation;
    restraints
        spring
            sixDoFRigidBodyMotionRestraint        linearSpring;
            anchor                                (0 1.8 0);
            refAttachmentPt                        (0 0 0);
            stiffness                            40000;
            damping                                3.47246454;
            restLength                            1.8;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
motionSolver    sixDoFRigidBodyMotion;
patches         (cylinder);
innerDistance   0.3;
outerDistance   1;
mass            4;
centreOfMass    (0 0 0);
momentOfInertia (1.958864357 3.920839234 2.057121362);
orientation
    0.9953705935 0.09611129781 0
    -0.09611129781 0.9953705935 0
    0 0 1
g               (0 -9.81 0);
rho             rhoInf;
rhoInf          1;
report          on;
solver
    type symplectic;
constraints
    fixedLine
        sixDoFRigidBodyMotionConstraint fixedAxis;
        axis (0 1 0)
    zAxis
        sixDoFRigidBodyMotionConstraint axis;
        axis                (0 0 1);
restraints
    verticalSpring
        anchor          (0 1.8 0);
        stiffness       4000;
        damping         2;
        restLength      1.8;
Is it possible to implement restraints and solid body motion solvers into the immersed boundary method? How would I accomplish this?
Thanks!
andrewbickerdike likes this.
courant_numero_uno is offline   Reply With Quote
Old   October 12, 2019, 11:26
To answer my own question, there is a good tutorial here:
http://www.tfd.chalmers.se/~hani/kur...eirsson/OF.pdf
Though I had some issues with the code which I posted about here:
OpenFOAM Immersed Boundary Method - forceBased motion class creation
Additionally, this tutorial seems to encounter issues with the forces jumping sporadically.. believe this issue is due to the way the code uses loops. In my code, I implemented an "acceleration relaxation/damping" which sort of helps mitigate the sudden jumping, but I'm still working on getting it to run smoothly.
Old   November 22, 2021, 09:28
Andrew Bickerdike
andrewbickerdike is on a distinguished road
Did you manage to get this code working?
Thanks.
andrewbickerdike is offline   Reply With Quote
Solid body motion on boundary and not entire mesh twinturbotom OpenFOAM Running, Solving & CFD 1 June 5, 2020 07:02
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Drawing 3d body and immersed boundary method (IBM) quarkz Main CFD Forum 0 December 16, 2011 17:59
Immersed Boundary Ghost Cell Method thehexman Main CFD Forum 1 February 5, 2010 06:10
