calculating distance between neighboring points
Old   March 6, 2022, 07:56
Default calculating distance between neighboring points
Kuang-Wu Lee
kuangwulee is on a distinguished road
Hello Foamers,
I have a very fundamental question: how can we calculate the distance between neighboring mesh points (not the distance from mesh point to surface.)
can someone help me?? thanks
Jeff
kuangwulee is offline   Reply With Quote
Old   March 6, 2022, 09:54
Tobermory will become famous soon enough
What do you mean by "neighboring mesh points"? Do you mean the distance between the centre of a cell and the centre of its neighbouring cells? Since this is an unstructured mesh, then you need to start by getting the cell numbers of the neighbouring cells, and their cell centres, and then it's simple trigonometry to get the separation distance. Is that what you are after?
Tobermory is offline   Reply With Quote
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 07:35
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 10:43
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
