Conservative Flux in (in-)compressible PimpleFoam
Old   March 30, 2022, 06:19
Question Conservative Flux in (in-)compressible PimpleFoam
Adrian
LateinCecker is on a distinguished road
Hello Everyone,
i have recently gotten into CFD and i have been exploring the OpenFOAM source code a bit to better understand whats going on. Specifically, i have been looking into the incompressible/pimpleFoam and the compressible/rhoPimpleFoam solvers and i think by now i have a farely good grasp at what most of the code does. But there is one thing that strikes me as odd in the pressure equation sections of both solvers (pEqn.H):
After the pressure equation is solved, in the last non-orthogonal corrector loop the conservative flux
phi
is corrected. For the incompressible solver (pimpleFoam/pEqn.H) the corresponding code looks like this:
phi = phiHbyA - pEqn.flux();
which, from what i understand is equivalent to
\phi_f  = \boldsymbol S_f \cdot \left( \frac{H(\boldsymbol U)}{A_P} \right)_f -  \underbrace{\boldsymbol S_f \cdot \left( \frac{\boldsymbol \nabla  p}{A_P} \right)_f}_{\text{pEqn.flux}}
and becomes
\phi_f  = \boldsymbol S_f \cdot \left( \frac{H(\boldsymbol U)}{A_P} \right)_f -  \left( \bigl| \frac{\boldsymbol \Delta}{(A_p)_f} \bigr| \, \frac{p_N -  p_P}{d} + \frac{\boldsymbol k}{(A_p)_f} \cdot (\boldsymbol \nabla p)_f  \right)
where the surface element [math] S = \Delta + k [\math]. This is all good and i get where it is coming from. The problem lies in the comparison to the compressible solver (rhoPimpleFoam/pEqn.H):
Here, the correction to the conservative flux is written as
phi = phiHbyA + pEqn.flux();
so the sign of the
 pEqn.flux()
is flipped. As i understand it, the
.flux()
function should be functionally identical to the incompressible case, except that now the density \rho is a factor:
\phi_f =  \boldsymbol S_f \cdot \left( \rho \, \frac{H(\boldsymbol U)}{A_P}  \right)_f - \underbrace{\boldsymbol S_f \cdot \left( \rho \,  \frac{\boldsymbol \nabla p}{A_P} \right)_f}_{\text{pEqn.flux}}
\phi_f  = \rho_f \, \boldsymbol S_f \cdot \left( \frac{H(\boldsymbol U)}{A_P}  \right)_f - \left( \bigl| \left( \frac{\rho}{A_p} \right)_f \boldsymbol  \Delta \bigr| \, \frac{p_N - p_P}{d} + \left( \frac{\rho}{A_p} \right)_f  \boldsymbol k \cdot (\boldsymbol \nabla p)_f \right)
So if these equations are correct, then why is the sign for
pEqn.flux()
flipped in the compressible solver?
I hope this is the right forum for this question. Thx already in advance
LateinCecker is offline   Reply With Quote
pimplefoam, pressure and velocity, rhopimplefoam
solver crashing hrishikeshsivanandan OpenFOAM 7 March 6, 2021 01:18
Flux splitting for compressible flow using finite difference method Amr Emad Ezzat Main CFD Forum 2 February 10, 2020 05:13
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
