Anisotropic thermal conductivity in CHT SimpleFoam |
April 21, 2022, 04:57 |
Sunag R A
Rep Power: 6 |
Dear all,
I am running an anisotropic thermal conductivity using chtMultiRegionSimpleFoam solver. The simulation has two solid regions. Spherical region embedded inside a hemispherical region named as tumor and gland. I have attached the case file for reference. Thermophysical property: 1. The anisotropic thermal properties for both the regions are as mentioned below: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object solidThermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heSolidThermo; mixture pureMixture; transport constAnIso; //transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } coordinateSystem { type cartesian; // global co-ordinate system (redundant) origin (0.006713780918727913 0.032 -0.006082474226804117); coordinateRotation { type cylindrical; // local Cartesian co-ordinates //e3 (0 0 0); e3 (0 0 1); // axis of rotation } } mixture { specie { molWeight 0; } transport { kappa (0.48 0.1 0.1); //kappa 0.51; } thermodynamics { Hf 0; Cp 3770; } equationOfState { rho 1050; } } // ************************************************************************* // 1. From the above thermophysical property, I could understand that the heat will flow radially since it has mode kappa value and directed along the z axis of rotation. 2. Based on this understanding, I expect my resulting simulation such that the heat from the internal sphere should move upwards (y coordinate in design) acting as a source. The outer boundary is impemented with convection BC with an ambient temperature of 22, while the spherical tumor source is having initial temperature of 38. The simulation is steady state. But, in my simulation, the heat is moving downwards as it can be seen after the simulation in the image presented below. I tried the axis values with (-1) and also with other direction like tangential kappa. What is wrong in my thermophysical properties as such? I have attached the complete project file in a zip. Simulation image after 100 iterations. https://drive.google.com/file/d/1SaR...ew?usp=sharing Zip_file link https://drive.google.com/file/d/1WVh...ew?usp=sharing 1. The file is of size 84 MB. Please run and provide if anything missing. 2. The mesh has been run, please run "chtMultiRegionSimpleFoam" and create all.foam later on to check the results. Please feel free to check other boundary conditions also and provide feedback so that I can improve upon the problem. Regards, Sunag R A. Last edited by sunagra27; April 21, 2022 at 04:59. Reason: Image link attached |
anisotropic, anisotropic conductivity, kappa, openfoam, thermophysical |
Anisotropic Thermal Conductivity in CFX 16.0 | ZahirUZ | CFX | 4 | March 27, 2019 04:54 |
Question about anisotropic thermal conductivity | Szweyk | STAR-CCM+ | 2 | June 30, 2016 08:26 |
Thermal conductivity issue | Jared1986 | CFX | 3 | March 20, 2014 10:38 |
IAPWS water properties + orthotropic thermal conductivity | Chander | CFX | 1 | February 29, 2012 17:26 |
Anisotropic Thermal Conductivity | Saturn | CFX | 4 | January 30, 2007 12:34 |
