free surface elevation"Interpolation for interface capturing"
Old   May 28, 2022, 04:54
Default free surface elevation"Interpolation for interface capturing"
Basar H.Ibrahim
Pasar is on a distinguished road
Hello everybody!
Currently, I'm working on the Wedge entry problem. the wedge is entering the water vertically down with a specified constant speed, when the water is at rest.
I'm using OpenFOAM v2106, using dynamicOversetFvMesh and the multiSolidBodyMotionSolver with linearMotion function as I've attached below.
Most of the settings I used are taken from the overInterDyMFoam tutorials.
I've attached the following files:
dynamicMeshDict
controlDict
fvSchemes
fvSolution
Unfortunately, I noticed I have a spurious free surface elevator, and the water interface along the wedge doesn't look very good, see the attached pictures.
Can anybody give me any advice on where is the problem or which scheme I should use?
Any description would be much appreciated!
Thanks in advance for your comments!
regards,
Basar Huzni
Pasar is offline   Reply With Quote
interface advection, interface bc, interface capture, interface compression, scheme file
What are Free Surface Level and Bottom Level beratcagan FLUENT 1 December 6, 2021 20:40
how to capture free surface cells? MichaelVS FLUENT 1 June 10, 2015 02:18
Floating dok on waves: free surface divergence Galchenko CFX 3 September 11, 2014 18:04
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 19:36
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
