February 22, 2023, 09:09 |
DPMFoam error with sphere drag
Turhan
Rep Power: 3 |
Dear all,
I am trying to simulate a water/sand slurry inside a pipe. For this I first used the icoUncoupledKinematicParcelFoam solver. This worked fine and gave no errors. However, since the interaction of particle to fluid is important, I wanted to transition to using DPMFoam. When doing this I get an error, and in this error I see certain terms such as KinematicCloud, SphereDragForce, ParticleForceList. This gives me an idea about where the error is located, but I am unable to figure out how to solve it since I don't see why exactly an error occurs there. Could someone help me out with figuring out what could cause the error? Solving2-D cloud kinematicCloud #0 Foam::error:: printStack(Foam::Ostream&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::SphereDragForce<Foam::KinematicCloud<Foam::C loud<Foam::CollidingParcel<Foam::KinematicParcel<F oam:: particle> > > > >::calcCoupled(Foam::CollidingParcel<Foam::Kinemat icParcel<Foam:: particle> > const&, Foam::KinematicParcel<Foam:: particle>::trackingData const&, double, double, double, double) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/liblagrangianIntermediate.so #4 Foam::ParticleForceList<Foam::KinematicCloud<Foam: :Cloud<Foam::CollidingParcel<Foam::KinematicParcel <Foam:: particle> > > > >::calcCoupled(Foam::CollidingParcel<Foam::Kinemat icParcel<Foam:: particle> > const&, Foam::KinematicParcel<Foam:: particle>::trackingData const&, double, double, double, double) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #5 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #6 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #7 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #8 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #9 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #10 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #11 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #12 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam #13 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #14 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam Floating point exception (core dumped) |
March 13, 2023, 05:58 |
Turhan
Rep Power: 3 |
I have worked it out and like to explain to those who may get this error.
I solved this by using the goldsmith tutorial (Which also uses DPMFoam) as a base and then adjust this into the simulation I want to do. I changed the geometry, boundary conditions, etc and looked if an error occured when doing this. (At first I did this to see where I was wrong) However, when I completely changed the tutorial into the simulation I wanted to do, the error did not even occur and the simulation worked. So my suggestion to myself and anyone having this error is to first take a tutorial which uses the same solver. And then change the parameters step by step until it fully changes in whatever you wish to simulate. |
dpmfoam, lagrangian, particles, sediment transport |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
Study of smooth sphere drag vs golf ball drag | tkolba | FLUENT | 2 | May 4, 2015 03:59 |
Guidance sought - drag of a sphere with bump | Europa | OpenFOAM Running, Solving & CFD | 0 | February 5, 2015 10:51 |
CFX analysis of a sphere - drag too low | Rob Findlay | CFX | 6 | March 26, 2007 10:11 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
