DPMFoam error with sphere drag
Old   February 22, 2023, 09:09
Default DPMFoam error with sphere drag
Turhan
Turhan is on a distinguished road
Dear all,
I am trying to simulate a water/sand slurry inside a pipe. For this I first used the icoUncoupledKinematicParcelFoam solver. This worked fine and gave no errors. However, since the interaction of particle to fluid is important, I wanted to transition to using DPMFoam. When doing this I get an error, and in this error I see certain terms such as KinematicCloud, SphereDragForce, ParticleForceList. This gives me an idea about where the error is located, but I am unable to figure out how to solve it since I don't see why exactly an error occurs there.
Could someone help me out with figuring out what could cause the error?
Solving2-D cloud kinematicCloud
#0 Foam::error:: printStack(Foam::Ostream&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2 ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3 Foam::SphereDragForce<Foam::KinematicCloud<Foam::C loud<Foam::CollidingParcel<Foam::KinematicParcel<F oam:: particle> > > > >::calcCoupled(Foam::CollidingParcel<Foam::Kinemat icParcel<Foam:: particle> > const&, Foam::KinematicParcel<Foam:: particle>::trackingData const&, double, double, double, double) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/liblagrangianIntermediate.so
#4 Foam::ParticleForceList<Foam::KinematicCloud<Foam: :Cloud<Foam::CollidingParcel<Foam::KinematicParcel <Foam:: particle> > > > >::calcCoupled(Foam::CollidingParcel<Foam::Kinemat icParcel<Foam:: particle> > const&, Foam::KinematicParcel<Foam:: particle>::trackingData const&, double, double, double, double) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#5 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#6 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#7 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#8 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#9 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#10 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#11 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#12 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
#13 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#14 ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/DPMFoam
Floating point exception (core dumped)
Turhan is offline   Reply With Quote
Old   March 13, 2023, 05:58
Turhan
I have worked it out and like to explain to those who may get this error.
I solved this by using the goldsmith tutorial (Which also uses DPMFoam) as a base and then adjust this into the simulation I want to do.
I changed the geometry, boundary conditions, etc and looked if an error occured when doing this. (At first I did this to see where I was wrong)
However, when I completely changed the tutorial into the simulation I wanted to do, the error did not even occur and the simulation worked.
So my suggestion to myself and anyone having this error is to first take a tutorial which uses the same solver. And then change the parameters step by step until it fully changes in whatever you wish to simulate.
dpmfoam, lagrangian, particles, sediment transport
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
Study of smooth sphere drag vs golf ball drag tkolba FLUENT 2 May 4, 2015 03:59
Guidance sought - drag of a sphere with bump Europa OpenFOAM Running, Solving & CFD 0 February 5, 2015 10:51
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 10:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
