internal velocity doesn't change in rhocentralfoam |
April 25, 2023, 01:09 |
Song Young Ik
Rep Power: 4 |
I am currently running supersonic free stream simulation on rhocentralfoam
However, when I try to set velocity of internal field over mach 1, e.g. 1.5, It crashes with error 'Negative initial temperature' while calculating e So, I reduced initial velocity to M 0.8, and set boundary to 1.5 so shock doesn't occur initially on the body and crash the computation, but it can slowly converge to result. It did converge, but when I postprocess and watch it, it shows internal flow velocity is below M1 everywhere. I set inlet to supersonicFreestream boundary condition, and outlet as inletOutlet . Is there way to get rid of 'Negative initial temperature' problem, or make internalfield adapt to boundary condition velocity value, which is 1.5? |
compressible, negative initial temp, rhocentralfoam, supersonic, velocity |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 457 | March 27, 2024 00:59 |
How can it possible to change by itself in volumetric flow rate of velocity inlet BC | oozcan | FLUENT | 10 | November 25, 2016 04:54 |
Use Wall Friction velocity for calculation in internal Field | juhuettn | OpenFOAM Programming & Development | 0 | March 4, 2015 10:57 |
velocity inlet with time related change of the magnitude | mobby90 | STAR-CCM+ | 2 | February 4, 2015 04:38 |
mean velocity change from inlet to outlet | ro | FLUENT | 2 | April 19, 2008 13:37 |
