Modelling Stirred Tank Reactor Agitated By Magnetic Rod Stirrer (No Baffles)
Old   July 14, 2023, 09:19
Default Modelling Stirred Tank Reactor Agitated By Magnetic Rod Stirrer (No Baffles)
ASR
sr786 is on a distinguished road
I am looking to use OpenFOAM to model an unbaffled stirred tank reactor agitated by a magnetic rod stirrer (located as base of reactor) as shown in image. The system will consist of air-water, where the interface between the two phases will deform inducing a vortex. I've simulated this case before in ANSYS FLUENT.
As the case is quite complex (including rotating stirrer, multi-phase flow, etc) I need advice on how to go about setting up this case (i.e., a workflow).
I know I want to use a single reference frame (SRF) model for the rotation, and Volume of Fluid (VOF) to track free surface deformation.
Also, what advice would you give in regards to meshing tool. I know OpenFOAM has an inbuilt mesher (snappy hexmesh) which can produce hexes. How easy will it be to implement hexes for my geometry as previously I've used a tet mesh using ANSYS Mesher?
sr786 is offline   Reply With Quote
Old   August 21, 2023, 02:52
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Have you solved this already? I have extensive experience with this and could guide you including OpenFOAM and snappy.
alfa_8C is offline   Reply With Quote
Old   August 21, 2023, 03:26
ASR
I’ve managed to set up a single phase run (tank filled with water) using single reference frame to model stirrer rotation.
I haven’t used Snappyhexmesh but instead used Salome to generate an unstructured mesh. So far simulation results look okay, not progressed to multi-phase solver yet
Old   August 21, 2023, 05:41
Antonio Liggieri
I am not sure if simpleSRFFoam have coriolis forces implemented. I'd recommend to use MRF instead. Corresponding tutorials can be found.
MRF solvers are created at runtime and can be used for multi-phase too. I don't think this is possible for simpleSRFFoam.
Old   August 21, 2023, 11:25
ASR
No worries and thank you for the advice. How would I implement a SRF using MRF in OpenFOAM.
I only have one cell zone defined which includes all the cells in the computational domain.
Old   August 26, 2023, 09:38
Antonio Liggieri
Hi, I can provide a sample case, but I cannot share a link here. Can you please provide an email address where to share the link to?
Old   August 26, 2023, 10:51
ASR
Hi I've forwarded it to you via PM.
Old   April 10, 2024, 06:57
Ruonin is on a distinguished road
hijacking a bit this thread to prevent creating duplicates.
I'm also interested in this kind of simulation for magnetic bar stirrers.
Were you successful in your simulation? Also, did you tracked/calculated the torque?
Best,
R
Ruonin is offline   Reply With Quote
Old   April 10, 2024, 08:40
Antonio Liggieri
I do these simulations with OpenFOAM and generally speaking these kind of simulations are pretty standard, in particular with MRF. So running them successfully shouldn't be e big deal.
In OpenFOAM, torque can be written out by the forces and moments function in the controlDict.
Issue with implementing kOmegaSST model in steady state stirred tank simulation WJPeace1 OpenFOAM Running, Solving & CFD 0 July 12, 2023 12:44
Modelling stirred tank reactors Nishant FLUENT 4 January 24, 2011 12:45
Stirred Tank Reactor Modelling alice FLUENT 2 January 23, 2011 14:59
sliding mesh for stirred tank modelling Gopal Kasat FLUENT 0 June 24, 2005 05:38
CFX 5.5.1 stirred tank and LES problem Nishant CFX 2 September 13, 2002 07:11
