Modelling Stirred Tank Reactor Agitated By Magnetic Rod Stirrer (No Baffles) |
July 14, 2023, 09:19 |
sr786
Rep Power: 3 |
I am looking to use OpenFOAM to model an unbaffled stirred tank reactor agitated by a magnetic rod stirrer (located as base of reactor) as shown in image. The system will consist of air-water, where the interface between the two phases will deform inducing a vortex. I've simulated this case before in ANSYS FLUENT. As the case is quite complex (including rotating stirrer, multi-phase flow, etc) I need advice on how to go about setting up this case (i.e., a workflow). I know I want to use a single reference frame (SRF) model for the rotation, and Volume of Fluid (VOF) to track free surface deformation. Also, what advice would you give in regards to meshing tool. I know OpenFOAM has an inbuilt mesher (snappy hexmesh) which can produce hexes. How easy will it be to implement hexes for my geometry as previously I've used a tet mesh using ANSYS Mesher? Geometry.png |
August 21, 2023, 02:52 |
Antonio Liggieri
Rep Power: 14 |
Have you solved this already? I have extensive experience with this and could guide you including OpenFOAM and snappy. |
August 21, 2023, 03:26 |
sr786
Rep Power: 3 |
I’ve managed to set up a single phase run (tank filled with water) using single reference frame to model stirrer rotation. I haven’t used Snappyhexmesh but instead used Salome to generate an unstructured mesh. So far simulation results look okay, not progressed to multi-phase solver yet |
August 21, 2023, 05:41 |
Antonio Liggieri
Rep Power: 14 |
I am not sure if simpleSRFFoam have coriolis forces implemented. I'd recommend to use MRF instead. Corresponding tutorials can be found.
MRF solvers are created at runtime and can be used for multi-phase too. I don't think this is possible for simpleSRFFoam. |
August 21, 2023, 11:25 |
sr786
Rep Power: 3 |
No worries and thank you for the advice. How would I implement a SRF using MRF in OpenFOAM. I only have one cell zone defined which includes all the cells in the computational domain. Last edited by sr786; August 21, 2023 at 17:04. |
August 26, 2023, 09:38 |
Antonio Liggieri
Rep Power: 14 |
Hi, I can provide a sample case, but I cannot share a link here. Can you please provide an email address where to share the link to?
August 26, 2023, 10:51 |
sr786
Rep Power: 3 |
Hi I've forwarded it to you via PM.
April 10, 2024, 06:57 |
Rep Power: 15 |
hijacking a bit this thread to prevent creating duplicates. I'm also interested in this kind of simulation for magnetic bar stirrers. Were you successful in your simulation? Also, did you tracked/calculated the torque? Best, R |
April 10, 2024, 08:40 |
#9 |
Antonio Liggieri
Rep Power: 14 |
I do these simulations with OpenFOAM and generally speaking these kind of simulations are pretty standard, in particular with MRF. So running them successfully shouldn't be e big deal. In OpenFOAM, torque can be written out by the forces and moments function in the controlDict. |
Issue with implementing kOmegaSST model in steady state stirred tank simulation | WJPeace1 | OpenFOAM Running, Solving & CFD | 0 | July 12, 2023 12:44 |
Modelling stirred tank reactors | Nishant | FLUENT | 4 | January 24, 2011 12:45 |
Stirred Tank Reactor Modelling | alice | FLUENT | 2 | January 23, 2011 14:59 |
sliding mesh for stirred tank modelling | Gopal Kasat | FLUENT | 0 | June 24, 2005 05:38 |
CFX 5.5.1 stirred tank and LES problem | Nishant | CFX | 2 | September 13, 2002 07:11 |
