Because of skewness
Old   May 3, 2007, 05:56
Default Hi all, I need some help fr
lam
Hoang-Lam
lam is on a distinguished road
Hi all,
I need some help from you.
I use the simpleFoam solver with laminar flow, and turbulence off.
And my geomtries are converted by gmsh2ToFoam.
But each time, I make a computation on a complexe geometrie, checkMesh tells me that I have a lot faces which have a "Severe non-orthogonality" (but it's said finally: "Non-orthogonality check OK.") so I do not care (should I?).
But I really get worried about the rate of "Max skewness" which is about 2000% (and more for the other meshes I have)!! checkMesh says to me "This may impair the quality of the result."
And each time, my computation failed (the sum local, and the p initial residual went off!)
And of course, I can not improve the quality of my meshes before doing the conversion into Foam.
My question: is how can I try to use Finit Element discretisation, instead of Finite Volume discretisation in Foam? I think I need something like "fvSchemes" dictionnary but for Finite Element, isn't it?
(I do not know if it may improve my computation, but I really want to try to use it. )
Thanks in advance,
Lam
lam is offline   Reply With Quote
skewness chouki FLUENT 0 September 4, 2007 10:41
skewness Donia FLUENT 1 June 1, 2007 14:05
skewness sam FLUENT 2 March 6, 2007 23:26
must improve skewness ? mario FLUENT 4 January 31, 2007 09:10
Skewness Taskin FLUENT 5 April 6, 2005 15:21
