POROUS MATERIAL
Old   October 19, 2005, 16:19
Default Does nayone knows if OpenFoam
Muzio Grilli
maritozzo is on a distinguished road
Does nayone knows if OpenFoam is able to simulate a porous material.
Please answer
maritozzo is offline   Reply With Quote
Old   October 19, 2005, 23:29
Default I think it depends on what do
Billy
billy is on a distinguished road
I think it depends on what do you want to simulate.
OpenFOAM is flexible and can simulate many things.
If there is no application that suits your needs, you can always build your own.
billy is offline   Reply With Quote
Old   October 20, 2005, 05:27
Default You simply have to add the Dar
Assistant Moderator
Bernhard Gschaider
You simply have to add the Darcy-term to the velocity-equations (in other words: write a solver for this)
But there is no out-of-the-box solver for this (and there is always the problem how you define which parts of the geometry are porous and which are not)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 20, 2005, 12:09
Default so substantially you are telli
Muzio Grilli
so substantially you are telling me that i have to connect two different solvers, one when i'm out of the box and another one when i'm in the box, have you ever done something like this?
Old   October 20, 2005, 12:22
Default Sorry. With "out-of-the-box" I
Assistant Moderator
Bernhard Gschaider
Sorry. With "out-of-the-box" I meant "a solver available in the OF-distribution". You'll have to write a solver yourself.
One approach would be to simply extend an existing solver by adding Darcy as a source-term. In the Darcy-term there is a permeability/resistivity (whatever formulation you prefer). By using a field for that and specifying appropriate values for certain regions you can define porous/non-porous-zones.
That approach has some problems at the porous/non-porous-interfaces.
Old   October 20, 2005, 12:40
Default You're telling me to treat it
Muzio Grilli
You're telling me to treat it as a boundary condition?
I have to make the flux pass through a zone which i define as a porous zone and i have to evaluate the consequent pressure loss
Sorry if i'm a little bit boring but i have to do this as a thesis job, so what kind of approach do you think would be best?
Old   October 24, 2005, 07:14
Default @boundary condition: No. You j
Assistant Moderator
Bernhard Gschaider
@boundary condition: No. You just implement an additional source-term. I just wanted to warn you, that there might be problems at the porous/non-porous-interface
Is your whole simulation domain a porous body with a homogenous permeability or is your setup of the type: inlet/Navies-Stokes-Flow/porous body (Darcy)/NS-Flow/outlet? My above comments were always meant for the second case.
Old   October 24, 2005, 15:22
Default I'm in the second condition,wi
Muzio Grilli
I'm in the second condition,with inlet, NS flow, porous body, NS flow, and outlet.
Do you know a different approach to avoid the problems at the porous non porous inteface?
Old   October 24, 2005, 18:31
Default No. Sorry. But I'll tell you w
Assistant Moderator
Bernhard Gschaider
No. Sorry. But I'll tell you when I find out.
Anyway: these effects are only significant for low permeabilities.
Old   October 25, 2005, 06:48
Default I found the Navier-Stokes-Brin
Muzio Grilli
I found the Navier-Stokes-Brinkman equation
which is
U*grad(U)-nu*laplacian(U)-nu*U/K=(1/rho)*grad(p)
where nu is the kinematic viscosity and K represents the permeability tensor.
So I should simply add the term -nu*U/K
I looked at simpleFoam solver and i found this
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
+ turbulence->divR(U)
UEqn().relax();
solve(UEqn() == -fvc::grad(p));
I have some questions
1)Where is the division by rho regarding grad(p), because i foundend in the programmer guide that R represents nu(eff)*gradU and nu is the kinematic visvosity.
2)If the equation is right i should simply define the K tensor in the porous media domain the change the equation to this form
fvm::div(phi, U)
+ turbulence->divR(U)+(nu/K)*U
UEqn().relax();
Please tell me if i've made some syntax error
Old   October 25, 2005, 07:12
Default This looks good. I would sugge
  #11
Assistant Moderator
Bernhard Gschaider
This looks good. I would suggest using fvm::Sp or fvm::SuSp for an implicit treatment of the source term.
Old   October 25, 2005, 07:21
Default You mean like this tmp
  #12
Muzio Grilli
You mean like this
fvm::div(phi, U)
+ turbulence->divR(U)+nu*fvm::SuSp(U,G)
UEqn().relax();
P.S. ; I'dont have to worry about the lack of density?
Old   October 25, 2005, 07:23
Default Sorry G is the inverse of K te
  #13
Muzio Grilli
Sorry G is the inverse of K tensor
Old   October 25, 2005, 07:28
Default If you switch positions of U a
  #14
Assistant Moderator
Bernhard Gschaider
If you switch positions of U and G: Yes.
Old   October 25, 2005, 11:57
Default Sorry Bernhard but from my que
  #15
Muzio Grilli
Sorry Bernhard but from my questions i think you understood i'm very new in using OpenFoam, so i need some more hints, i know i'm boring, i'm trying to define the field of the permeability tensor and i really don't know how to begin.
I thaught to convert setGammaDambreak utility to my case but it only defines the initial field and it works on an already existing field it doesn't define a new one.
In createFields.H i also observed that it creates the fields reading from existing files.
Futhermore i think I should define the field as a volTensorField so that it refers to cell centers or i have to define it as a pointfield
Please answer
Old   October 25, 2005, 13:31
Default Density: the incompressible co
  #16
Mattijs Janssens
mattijs is on a distinguished road
Density: the incompressible codes tend to solve for U/rho, p/rho etc. (see the dimensions in the fields) with density set to 1.
mattijs is offline   Reply With Quote
Old   October 28, 2005, 06:59
Default Hi Muzio! When developing a
  #17
Assistant Moderator
Bernhard Gschaider
Hi Muzio!
When developing a new solver you should be prepared to edit the files for the initial conditions.
Copy an existing field-file (p for example) and edit it: 1. set the correct dimensions 2. set correct boundary conditions (zeroGradient should be alright for the permeability).
The you can use damBreak-derived utility on that (or you might have a look at the setFields-utility which is new in 1.2 and might just do what you're looking for).
@tensorField: do you have directed permeabilities? if not a scalar would be sufficient.
Old   November 7, 2005, 07:31
Default Hi Bernhard I wrote the solver
  #18
Muzio Grilli
Hi Bernhard I wrote the solver and i used it but i had very bad results (negative pressure for example).
I found that when i write
nu*fvm::SuSp(U,G)
this only discretizes G in a implicit or explicit way depending on the sign of U, and that is not correct, so i discretized it as an explicit term
This is the .C file I used
#include "fvCFD.H"
#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
#include "incompressible/turbulenceModel/turbulenceModel.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
# include "created.H"
# include "createG.H"
# include "createNu.H"
# include "initContinuityErrs.H"
//mesh.clearPrimitives();
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readSIMPLEControls.H"
p.storePrevIter();
// Pressure-velocity SIMPLE corrector
// Momentum predictor
fvm::div(phi, U)
+ (1.0+2.5*(1.0-d))*turbulence->divR(U)+nu*G*U
UEqn().relax();
p.boundaryField().updateCoeffs();
volScalarField AU = UEqn().A();
U = UEqn().H()/AU;
UEqn.clear();
phi = fvc::interpolate(U) & mesh.Sf();
adjustPhi(phi, U, p);
// Non-orthogonal pressure corrector loop
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(1.0/AU, p) == fvc::div(phi)
fvScalarMatrix::reference pRef =
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
pEqn.unsetReference(pRef);
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
p.relax();
// Momentum corrector
U -= fvc::grad(p)/AU;
U.correctBoundaryConditions();
turbulence->correct();
runTime.write();
Info<< "ExecutionTime = "
<< runTime.elapsedCpuTime()
<< " s\n\n" << endl;
Info<< "End\n" << endl;
return(0);
PLEASE HELP ME find out where is my error
Old   November 7, 2005, 10:41
Default what error? first though, n
  #19
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
what error?
first though, nu*fvm::SuSp(U,G) is not the same
as fvm::SuSp(nu*G, U) which is what you should use,
second: why cant the pressure be negative?
niklas is offline   Reply With Quote
Old   November 7, 2005, 11:20
Default I'm analysing the flow of an i
  #20
Muzio Grilli
I'm analysing the flow of an incompressible fluid through a porous media inside and outside it, the therm which i have to introduce is -((nu)/K)*U
writing
fvm::SuSp(nu*G,U)where G=(K)^-1
i discretize only U and not the product -((nu)*G)*U
non-isotropic porous material gmmh FLUENT 0 September 4, 2007 06:38
Error while setting up porous material. Kiddo CFX 1 October 10, 2005 10:42
porous material ioana CFX 2 March 10, 2005 07:52
model for porous material sleepinglily CFX 3 October 19, 2004 10:45
Material in Porous media Rajab Rajab FLUENT 3 July 4, 2003 13:42
