January 4, 2005, 06:46 |
I am a newbie in LES and
I am a newbie in LES and turbulence, so forgive me if my question is silly... I have taken some of the functionality from dieselSpray to my own spray-class, but I have a question regarding the dispersionModel for LES. Aren't any models implemented yet, or is the dispersionLESModel just a dummy like noDispersion because only the largest eddies ( which of course are calculated by LES ) influences/disperses the particles (if they of course are "medium" size). |
January 4, 2005, 11:00 |
Yes, the LES dispersi
Yes, the LES dispersion models is only a dummy (no dispersion) since the spray-class must be compatible with both the LES and RANS codes. And I'm not sure it is needed either, at least not for spray applications. The spray will look 'random' anyway. Note that the dispersion models in FOAM are modified to reduce the dispersion as I found that the original models produce unrealisticly high dispersion, which can be seen when you turn off evaporation. |
Dispersion | haghajani | OpenFOAM Running, Solving & CFD | 0 | January 11, 2009 15:12 |
Turbulent Dispersion in Particle Tracking | ariel | CFX | 2 | April 22, 2008 22:02 |
Air dispersion modelling | Moied | CFX | 1 | May 24, 2005 18:35 |
HELP: diffusion & dispersion of particle method | QU KUN | Main CFD Forum | 0 | January 22, 2004 01:21 |
Turbulent dispersion | Julie Polyakh | Siemens | 0 | May 15, 2003 07:14 |
