Question surface tracking model
Old   February 5, 2009, 13:27
Default Hi is there any exapple of
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi
is there any exapple of surface tracking model can solve both bubble or droplet problem?i meaan something like 2-zone FVM flow solver, a FEM mesh motion solver and a finite area solver doing the surfactant transport,to calculated the flow in inner ,outer and surface of droplet or bubble.
i find some similar thing in Hrv`s presentation of free surface flow.but there is no example.
does anyone could give me some advices?
wayne
waynezw0618 is offline   Reply With Quote
Old   February 5, 2009, 15:20
Default Wayne, It is in the developme
David P. Schmidt
schmidt_d is on a distinguished road
Wayne,
It is in the development version of the code. Check on sourceforge.
-DPS
schmidt_d is offline   Reply With Quote
Old   February 6, 2009, 12:24
Default Hi David. i am using 1.5-dev
wayne.zhang
Hi David.
i am using 1.5-dev now.but i donot know which is the solver of that?
i mean some thing like http://powerlab.fsb.hr/ped/kturbo/Op...clean-mesh.mpg
wayne
Old   February 13, 2009, 05:08
Default Hi Wayne Look in this direc
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Wayne
Look in this directory. The solver "surfactantFoam" does at least use the FAM-routine.
~/OpenFOAM/OpenFOAM-1.5-dev/applications/solvers/surfaceTracking
Have fun,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 28, 2009, 10:12
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hi there,
today I installed and compiled the 1.5-dev.
The main reason therefore was the FAM. But unfortunately I am not able to execute the tutorial "sphereTransport" due to the error
Cannot find file "faceLabels" in directory "constant/faMesh".
What do I have to write into faceLabels? Or how can I produce the file "faceLabels"?
Solved it already with:
http://www.cfd-online.com/Forums/ope...rmation-2.html
Best,
Andreas
lord_kossity is offline   Reply With Quote
Old   May 29, 2009, 02:58
ngj
The command you should execute is "makeFaMesh" (or something similar, is not at a OF-machine).
I believe you can find the command in the Allrun file in the directory.
Best regards,
Niels
Old   March 1, 2010, 15:42
Default OpenFOAM liquid film solver
John.B
johnb is on a distinguished road
I am interested in thin liquid film flow simulation in OpenFOAM and eventually use this together with Lagrangian discrete particle tracking. I read (http://www.openfoamworkshop.org/2009...sak_slides.pdf) I wonder if this "OpenFOAM liquid film solver" has been implemented into OF 1.6.x? if not where can I found it (in the openfoam-extend?).
I would appreciate if someone could point me in the right direction.
Thanks in advance!
John
johnb is offline   Reply With Quote
Old   March 17, 2010, 16:20
John.B
Hi again,
Anyone that has done liquid film simulations using FAM method in openFOAM?
John
Quick Particle Tracking Question Daniel Tanner FLUENT 0 March 26, 2008 09:06
VOF--free surface tracking wanghong FLUENT 0 August 9, 2007 05:41
VOF free surface tracking LK FLUENT 2 May 20, 2006 12:20
"surface tracking" and "volume of fluid" ztdep Main CFD Forum 3 April 30, 2006 15:21
Particle Tracking...display on a surface Roland FLUENT 2 April 15, 2005 08:31
