Bug in 1.5-dev buoyantFoam - static pressure
Old   March 16, 2010, 17:39
Default Bug in 1.5-dev buoyantFoam - static pressure
David Gaden
marupio is on a distinguished road
Correct me if I'm wrong, but:
Should be:
p_static = rho_ref * g * h
The code uses:
p_static = rho_local * g * h
This assumes that rho_local is the same all the way up the fluid column, which it is not. A fluid element with low density (locally) will have an erroneously low p_static.
A reference density really is needed.
marupio is offline   Reply With Quote
Old   March 17, 2010, 09:13
David Gaden
Strike my last.
The hydrostatic pressure definition is different in buoyantFoam.
I didn't realize how the buoyancy momentum source related to the way hydrostatic pressure is defined. In general:
Sm = grad( p_hyd ) + rho g
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Static pressure at outlet - Stupid question??? Miry CFX 0 September 16, 2007 18:14
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
