Problem in running Parallel
Old   October 27, 2007, 12:43
Default Hello, I installed OF in /w
mou
mamaly60 is on a distinguished road
I installed OF in /work/mou/OpenFOAM/..., When I run "mpirun -np 4 interFoam . damBreak -parallel" and it worked perfect. but I know that it run 4 processes in 1 processor, because for having real parallelization I need to submit my job to the queue in cluster. When I use this command:"sqsub -q mpi -n 4 -o test.log interFoam . damBreak -parallel" it give me error.
srun: error: req555: task2: Aborted
srun: Terminating job
--> FOAM FATAL ERROR : bool Pstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor#0 Foam::error::printStack(Foam:stream&) in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::Pstream::init(int&, char**&) in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/openmpi-1.2.3/libPstream.so "
#3 Foam::argList::argList(int&, char**&, bool, bool) in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 main in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#5 __libc_start_main in "/lib/tls/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/work/mou/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
From function Pstream::init(int& argc, char**& argv)
in file Pstream.C at line 72.
FOAM aborting
[req555:18890] *** Process received signal ***
[req555:18890] Signal: Aborted (6)
[req555:18890] Signal code: (-6)
[req555:18890] [ 0] [0xffffe600]
[req555:18890] *** End of error message ***
Sender: LSF System <lsfadmin@lsfhost.localdomain>
Subject: Job 197478: </opt/hpmpi/bin/mpirun> Exited
Job </opt/hpmpi/bin/mpirun> was submitted from host <req770> by user <mou>.
Job was executed on host(s) <4*lsfhost.localdomain>, in queue <test>, as user <mou>.
</home/mou> was used as the home directory.
</work/mou/openfoam/mou-1.4.1/run/tutorials/interfoam> was used as the working directory.
Started at Fri Oct 26 10:55:30 2007
Results reported at Fri Oct 26 10:56:06 2007
Your job looked like:
# LSBATCH: User input
/opt/hpmpi/bin/mpirun -srun interFoam /work/mou/OpenFOAM/mou-1.4.1/run/tutorials/interFoam damBreakFine -parallel
Exited with exit code 134.
Resource usage summary:
CPU time : 0.22 sec.
Max Memory : 196 KB
Max Swap : 3 MB
The output (if any) is above this job summary.
I become so thankful if you review my problem.
Thank you
Mou
mamaly60 is offline   Reply With Quote
Old   April 19, 2010, 11:11
Default Any Solution to this Problem?
Michael B Martell Jr
theory37 is on a distinguished road
Hello Mou,
I know this post is ancient history, but I was wondering if you ever found a solution to this problem? I have tried installing OF 1.6 on a local cluster here, which has OF 1.5-dev installed and working properly ... all is well in serial, but I receive a very similar error when trying to run even a simple case (icoFoam cavity tutorial) in parallel.
Any help is greatly appreciated.
Mike
theory37 is offline   Reply With Quote
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
PROBLEM IN SOLVER RUNNING PARALLEL Íñigo CFX 3 February 4, 2007 05:08
InterFoam problem running parallel vatant OpenFOAM Running, Solving & CFD 0 April 28, 2006 19:22
Coupled problem running in parallel liu OpenFOAM Running, Solving & CFD 1 June 24, 2005 05:57
problem running parallel-help needed Shankar FLUENT 0 December 16, 2002 13:45
