pipe inside a room
Old   January 14, 2015, 16:43
Default pipe inside a closed domain
larry
christos is on a distinguished road
Hello OpenFOAM community,
I want to model the following case and I need some opinions from you regarding the necessary steps for running this case. Please see also attached figure!
A brief description of the problem is a pipe inside a closed domain. Hot air enters from the inlet of the pipe and leaves from the outlet of the pipe. This outlet is an internal face of the domain. How can I treat this problem if I don't care (for the moment) about the heat losses from the pipe walls.
1. How to deal with the outlet and the pipe walls which are internal surfaces of my domain?
2.What other dictionaries are necessary (createPatchDict?)
3. How to include pipe walls and outlet in SHMDict?
Can you please give me some hints/key points concerning my case.
Or better if there is any tutorial (e.x circular region inside another region) that has a generic similarity with my case so I can study it?
Thanks. Chris
Last edited by christos; January 16, 2015 at 05:26. Reason: better description of problem
christos is offline   Reply With Quote
Old   January 17, 2015, 18:09
larry
Ok I got it!. For those interested to know a workaround is to make the internal outlet as "shadow".
Best regards, Chris
buoyantsimplefoam, hotroom, pipe
Problems about phase-change simulation inside a heat pipe 6863523 FLUENT 7 October 14, 2014 10:07
How to simulate a simple fan inside a room ? rafiktharwat CFX 10 September 23, 2014 02:51
[DesignModeler] POROUS Media inside a pipe geometry creation gauravchauhan ANSYS Meshing & Geometry 0 April 12, 2014 04:15
Rotating Pipe inside a stationary pipe Richy STAR-CCM+ 3 February 7, 2013 04:10
Hydrogen concentration inside the battery room mazhar1613 ANSYS 0 August 15, 2011 02:31
