October 18, 2011, 19:14 |
buoyant flow in a horizontal duct
Ehsan
Rep Power: 16 |
hi,
I am trying to solve flow in a horizontal duct with inflow/outflow and constant temperature walls (top and bottom). I tried to solve it using buoyantPimpleFoam. I am not sure what I am doing wrong in my boundary conditions that give me unreasonable results. I will appreciate any helpful comments. my inlet BCs: U: inlet { type surfaceNormalFixedValue; refValue uniform -0.01; } T: inlet { type zeroGradient; } p: inlet { type calculated; value $internalField; } p_rgh: inlet { type fixedValue; value uniform 1e5; } |
October 19, 2011, 05:05 |
#2 | |
Roman Thiele
Rep Power: 20 |
so for T inlet BC, I would suggest Code:
inlet { type fixedValue; value uniform 293; // in case it is room temperature, }
~roman |
October 19, 2011, 11:57 |
Ehsan
Rep Power: 16 |
Roman,
Thank you for reply. I had already tested it with defined temperature and it would not help. The problem is I get reverse flow at inlet and also very large pressure inside the domain. Now, I define p_rgh, T, and U as a constant value (at inlet), and still get a wrong answer. Does anyone know what excatly the surfaceNormalFixedValue does at the inlet? How can I learn the way openfoam handles boundary conditions? Thank you, |
October 20, 2011, 02:53 |
inlet conditions and outlet conditions
Roman Thiele
Rep Power: 20 |
Inlet conditions
U: inlet { type fixedValue; value uniform (1 0 0); } p_rgh: inlet { type buoyantPressure; rho rhok; value uniform 1e5; } T: inlet { type fixedValue; value uniform 293; } outlet conditions U: outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } p_rgh: { type fixedValue; rho rhok; value uniform 1e5; } T: outlet { type zeroGradient; }
~roman |
October 20, 2011, 14:19 |
Ehsan
Rep Power: 16 |
thanks Roman,
I tried this and worked well: p_rgh: ----------- inlet { type zeroGradient; } outlet { type fixedValue; value uniform 1e5; } U: -------- inlet { type surfaceNormalFixedValue; refValue uniform -0.01; } outlet { type zeroGradient; } what does rho rhok; mean? does it matter if use fixedValue instead of buoyantPressure for p_rgh at outlet? thank you |
October 21, 2011, 02:03 |
#6 | |
Roman Thiele
Rep Power: 20 |
The description from OF for buoyantPressure is Code:
Description Set the pressure gradient boundary condition appropriately for buoyant flow. If the variable name is "pd" assume it is p - rho*g.h and set the gradient appropriately. Otherwise assume the variable is the static pressure.
~roman |
mass flow through a duct | wisemo | FLUENT | 0 | July 8, 2011 14:25 |
Turbulent Flow in a Square Duct using LES | Hock Ming | FLUENT | 0 | February 7, 2009 20:25 |
Flow direction in Buoyant flow | Nav | CFX | 4 | June 30, 2008 00:50 |
Modeling Turbulent Horizontal Buoyant Jets | Jack Travis | Main CFD Forum | 2 | September 11, 2006 06:36 |
in flow and out flow in a short duct | jane | Main CFD Forum | 0 | March 27, 2004 23:08 |
