October 4, 2019, 11:30 |
NACA 0012 Verification
Isaac
I have used the mesh from https://turbmodels.larc.nasa.gov/naca0012_grids.html. I have used the command plot3dToFoam to convert the p2dfmt of 896X512 points to Foam Mesh. I am using SA method, I am getting negative Cd values. the min y+ value is 0.007.
Link to the Files: https://drive.google.com/file/d/1TO8...ew?usp=sharing |
October 4, 2019, 13:14 |
Thiago Parente Lima
Hi isaac1326,
I saw that you changed the velocity vector direction to simulate the angle of attack. Once you did that, you have also to change the direction of the vector in which the OF calculates de lift (liftDir) and drag (dragDir). By definition, the lift vector is perpendicular to the free stream velocity and the drag is parallel to the same vector. Also, might try to reduce your residuals (and increase you endTime if you do so). Regards,
Fields of interest: buoyantFoam, chtMultRegionFoam. |
October 15, 2020, 17:56 |
Klaus
Rep Power: 22 |
You could create the mesh yourself using: https://sourceforge.net/projects/construct2d/
To change the AOA (angle of attack) it's usually easier to rotate the mesh using OpenFOAMs rotateMesh |
December 12, 2021, 06:44 |
Herpes Free Engineer
Rep Power: 12 |
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Data for NACA 0012 | Muntazir | Main CFD Forum | 1 | March 28, 2023 01:59 |
NACA 0012 Airfoil, simpleFoam, Spalart Allmaras | badwalgurpreet | OpenFOAM Running, Solving & CFD | 11 | December 29, 2021 18:04 |
XFlow Naca 0012 Validation | Mythorpios | Main CFD Forum | 1 | June 27, 2016 13:05 |
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 13:01 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 11:42 |
