wired error in sprayFoam
Old   June 13, 2012, 21:11
Default wired error in sprayFoam
conceptone is on a distinguished road
hi,everyone,i am a new openfoam user. I am running the sprayFoam case, where i implement the specie C12H26. I have changed the chem.inp and therm.dat. But when the case runs a few steps, it cracks. It stopped at 0.00151s.The error is like below:
Courant Number mean: 3.71158e-05 max: 0.0695979
deltaT = 1.25e-06
Time = 0.001515
Solving cloud sprayCloud
--> Cloud: sprayCloud
Added 6 new parcels
[6] #0 Foam::error:rintStack(Foam::Ostream&) in "/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
[6] #1 Foam::sigFpe::sigHandler(int) in "/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
[6] #2 __restore_rt at sigaction.c:0
[6] #3 __ieee754_exp at interp.c:0
[6] #4 exp in "/lib64/libm.so.6"
[6] #5 Foam::LiquidEvaporation<Foam::ReactingCloud<Foam:: ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam: :SprayParcel<Foam::ReactingParcel<Foam::ThermoParc el<Foam::KinematicParcel<Foam:article> > > > > > > > >::calculate(double, int, double, double, double, double, double, double, Foam::Field<double>&) const in "/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64Gcc44DPOpt/lib/liblagrangianSpray.so"
[6] #6 void Foam::ReactingParcel<Foam::ThermoParcel<Foam::Kine maticParcel<Foam:article> > >::calc<Foam::ReactingParcel<Foam::ThermoParcel<Fo am::KinematicParcel<Foam:article> > >::TrackingData<Foam::SprayCloud<Foam::ReactingClo ud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cl oud<Foam::SprayParcel<Foam::ReactingParcel<Foam::T hermoParcel<Foam::KinematicParcel<Foam:article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam:article> > >::TrackingData<Foam::SprayCloud<Foam::ReactingClo ud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cl oud<Foam::SprayParcel<Foam::ReactingParcel<Foam::T hermoParcel<Foam::KinematicParcel<Foam:article> > > > > > > > > >&, double, int) in "/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64Gcc44DPOpt/bin/sprayFoam"
Is there anybody who can help me? I guess it should be caused by particle or parcel parameters set in spraycloudProperties file, so I attached it. It can be open by word.
Thanks !
conceptone is offline   Reply With Quote
Old   June 16, 2012, 05:19
Retired Super Moderator
Bruno Santos
Greetings Conceptone,
An M$ Office Word file? Are you serious? Why didn't you attach the normal "spraycloudProperties" file? Perhaps packaged in zip format?
Lucky you that LibreOffice can open this blasphemous file format
Anyway, ranting aside: the error indicates that something went wrong when doing an exponential calculation, namely using "exp":
The "sigFpe" is a signal function for Floating Point Exception: http://en.wikipedia.org/wiki/SIGFPE - basically because "exp" tried to do something it shouldn't try to do.
The solution - use divide-and-conquer:
  1. Since you added a new model, you should validate it first. This is also a good exercise for you, so go search in the "OpenFOAM-*/applications" folder for applications that use chemistry and see if there is any that uses the chemistry set more explicitly. I think the "utilities" and "test" sub-folders are the best place to look.
  2. After you've validated that the equations and values were properly added to the "chem.inp" and "therm.dat" files, try a simpler version of this case you're running. Use a really smaller profile for initial particles.
  3. If this fails, you'll have to build the debug version of OpenFOAM, so you can get closer to where "exp" gave you the problem. Here you can also try the "gdbOF" plugin: http://openfoamwiki.net/index.php/Contrib_gdbOF
Good luck!
Bruno
PS: to close the loop on this thread, it looks like this was initially being followed here: http://www.cfd-online.com/Forums/ope...d-new-gas.html
Old   June 16, 2012, 14:27
Oh man, thanks your kind help! I'll check these things again..I'm just a new user coming through the period..
PSerhaps we should have a dinner together
of course I'm kidding!
Old   June 16, 2012, 17:27
Oh by the way is it true that if I want to run the debug version the openfoam should be installed on my own computer? I mean my openfoam is installed on the service computer, so I can't modify the bashrc file since I don't have the managing right.
Old   June 16, 2012, 17:31
Bruno Santos
You can easily do your own personal build of OpenFOAM - just follow the instructions: http://www.openfoam.org/download/source.php
As for the debug build, here's an old thread on this subject: http://www.cfd-online.com/Forums/ope...oam-1-6-a.html - and yes, you'll only need to build the debug version on your personal installation!
Old   June 16, 2012, 22:18
Thanks man!I tried the source pack from http://www.openfoam.org/download/source.php
But it seems it is only for version 2.1.1 while mine is 2.1.0 because when I type in source command "source $HOME/.cshrc" I got the error message from Linux:
elephant 166% source $HOME/.cshrc
/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.1/bin/foamEtcFile: Command not found.
/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.1/bin/foamCleanPath: Command not found.
/usr/apps1/openfoam-2.1.0/OpenFOAM-2.1.1/etc/config/settings.csh: No such file or directory
So is there any version for 2.1.0?
Old   June 16, 2012, 22:29
Luckly, I found the correct version by myself
XieXie!
Old   June 20, 2012, 22:10
Hi Bruno, the linux system manager has helped me to build the debug version(it seemed that it's not gdb) so I am not sure where should I find the so-called detail debug information. So I copy the message from log.sprayFoam file, can you help me about the error? Thanks.
[6] #0 Foam::error:rintStack(Foam::Ostream&) at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/OSspecific/POSIX/printStack.C:201
[6] #1 Foam::sigFpe::sigHandler(int) at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/OSspecific/POSIX/signals/sigFpe.C:117
[6] #5 Foam::exp(double) at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Scalar.H:260
[6] #6 Foam::NSRDSfunc1::f(double, double) const at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/thermophysicalModels/thermophysicalFunctions/lnInclude/NSRDSfunc1.H:108
[6] #7 Foam::C12H26:v(double, double) const at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/thermophysicalModels/properties/liquidProperties/C12H26/C12H26I.H:34
[6] #8 Foam::LiquidEvaporation<Foam::ReactingCloud<Foam:: ThermoCloud<Foam::KinematicCloud<Foam::Cloud<Foam: :SprayParcel<Foam::ReactingParcel<Foam::ThermoParc el<Foam::KinematicParcel<Foam:article> > > > > > > > >::calculate(double, int, double, double, double, double, double, double, double, double, Foam::Field<double> const&, Foam::Field<double>&) const at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/lagrangian/intermediate/lnInclude/LiquidEvaporation.C:172
[6] #9 void Foam::ReactingParcel<Foam::ThermoParcel<Foam::Kine maticParcel<Foam:article> > >::calcPhaseChange<Foam::ReactingParcel<Foam::Ther moParcel<Foam::KinematicParcel<Foam:article> > >::TrackingData<Foam::SprayCloud<Foam::ReactingClo ud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cl oud<Foam::SprayParcel<Foam::ReactingParcel<Foam::T hermoParcel<Foam::KinematicParcel<Foam:article> > > > > > > > > > >(Foam::ReactingParcel<Foam::ThermoParcel<Foam::Ki nematicParcel<Foam:article> > >::TrackingData<Foam::SprayCloud<Foam::ReactingClo ud<Foam::ThermoCloud<Foam::KinematicCloud<Foam::Cl oud<Foam::SprayParcel<Foam::ReactingParcel<Foam::T hermoParcel<Foam::KinematicParcel<Foam:article> > > > > > > > > >&, double, int, double, double, double, double, double, double, double, int, double, Foam::Field<double> const&, Foam::Field<double>&, double&, double&, double&, Foam::Field<double>&) at /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/lagrangian/intermediate/lnInclude/ReactingParcel.C:517
[pn1:29034] [21] sprayFoam [0x472099]
[pn1:29034] *** End of error message ***
mpiexec noticed that process rank 6 with PID 29034 on node pn1 exited on signal 8 (Floating point exception).
Old   June 21, 2012, 16:41
Bruno Santos
Seriously, stop posting on two threads the same question ... You've already been answered here: http://www.cfd-online.com/Forums/ope...tml#post367702 #13
Multiple Injection points in sprayFoam kripalpariyangat OpenFOAM Pre-Processing 13 October 29, 2022 01:22
aachenBomb with sprayFOAM not working jenzkeller OpenFOAM Bugs 8 June 8, 2014 18:01
sprayFoam crashes lukasfischer OpenFOAM Running, Solving & CFD 3 July 14, 2013 11:08
Standard Drag Model does not exist for sprayFoam arash1 OpenFOAM Running, Solving & CFD 0 April 8, 2012 17:52
sprayFoam results depend on the type of chemistryReader (chemkinReader/foamChemistry arash1 OpenFOAM Running, Solving & CFD 1 April 2, 2012 12:47
