July 21, 2011, 08:24 |
Boundary conditions in combustion Problem
José Rodrigues
Rep Power: 15 |
Hi
I am simulating a combustion chamber for flameless combustion with the outlet boundaries pretty close to the inlet boundaries. When I ignite the mixture, the simulation diverges (the temperatures get higher and higher) as the hot air gets closer to the outlet. I checked on the solution right before the crash and I saw that the outlet temperature did not changed as the hot gases approached with temperatures 2000k higher. 1) I am setting zeroGradient in this boundary, which should allow the outlet temperature to raise with the outgoing gases. Am I right?? 2) Also, a colleague suggested me use extrapolation to set the boundary values. How does OpenFoam do extrapolation for BCs? 3) What does $internalField do? For example in the dictionary Code:
Outlet { type fixedValue; value $internalField; } Thx |
Problem with Specifying Boundary Conditions | nakul | OpenFOAM | 1 | February 25, 2011 07:13 |
Problem with using periodic boundary conditions | Sun | FLUENT | 0 | January 14, 2011 09:47 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 08:59 |
Book | Jan Ramboer | Main CFD Forum | 5 | August 9, 1999 02:01 |
