Intel_mpirun and LSF
Old   February 9, 2013, 23:36
Default Intel_mpirun and LSF
ehk
ehsankf is on a distinguished road
Does anyone have any experience running OF from LSF?
If so, could you let me know how it is possible to run parallel job through mpirun.lsf command, which is an LSF version of "mpirun". Thanks.
ehsankf is offline   Reply With Quote
Old   February 10, 2013, 07:42
Retired Super Moderator
Bruno Santos
Greetings ehsankf,
I did a quick search with Google looking for:
OpenFOAM lsf
and found this post: http://www.cfd-online.com/Forums/ope...tform-lsf.html
edit: in fact, Google showed me several pages that explain how to this...
Best regards,
Bruno
Last edited by wyldckat; February 10, 2013 at 07:44. Reason: see "edit:" and refactored the google search line
Old   February 13, 2013, 01:07
ehk
Bruno, thank you very much for that information!
The mpirun.lsf is very like this:
bsub -a mpichp4 -n 8 -q p mpirun.lsf ./job.exe
As it is seen, the number of processors passed before mpirun command whch is not compatible with openFoam in which it is
mpirun -
n 8 -mycase -parallel.
Old   February 13, 2013, 04:41
Bruno Santos
Hi ehsankf,
It looks like you need to build OpenFOAM to link with the MPI your system has. I say this because "mpichp4" is not likely to be compatible with Open-MPI, which is why you're unable to launch a parallel run.
Since you mentioned Intel's MPI, check this thread for ideas: http://www.cfd-online.com/Forums/ope...intel-mpi.html
Best regards,
Bruno
Old   February 13, 2013, 14:03
ehk
Bruno,
I have already built OF with icc and intel_mpi. Since the platform is LSF, mpirun may launch lsf trough the following command:
mpirun.lsf ./job.exe. When I run OF, e.g,
mpirun.lsf interFoam -parallel
OF looks for the number of processors and complains that can not run on 1 processor.
it seems that this problem has already been fixed as it is seen here:
http://umbc.rnet.missouri.edu/resour...nOpenFOAM.html
but I do not have idea how it has been done.
Old   February 13, 2013, 16:18
Bruno Santos
Hi ehsankf,
Your description seems very incomplete. That very same link indicates that you need the whole script... possibly something like:
# Set job parameters
#BSUB -a openmpi
#BSUB -J jobname
#BSUB -oo jobname.o%J
#BSUB -eo jobname.e%J
# Set number of CPUs
#BSUB -n 4
# Start OpenFOAM job
mpirun.lsf interFoam -parallel > log.interFoam 2>&1
Running only with "mpirun.lsf interFoam -parallel" is not enough.
And the reference to "#BSUB -a openmpi" seems to indicate that it's something dependent on the configuration of your job scheduler. Have you asked your cluster's administrator?
Best regards,
Bruno
Old   February 13, 2013, 16:33
ehk
Actually it is never possible to run mpirun.lsf in command line since the variable LSF_PJL_TYPE can get value only through bsub script.
