Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend -
Old   February 27, 2013, 04:50
Unhappy Floating Point Exception - wrong boundaries or general PC problem? – OF 1.6 extend -
Andreas Wendy
A.Wendy is on a distinguished road
Hi Everybody,
Currently I am working on my masterthesis for a simulation of a gyrocopter including autorotation.
For that I started to modify the mixerGGI library to include a threedimensional autorotation.
I think I worked it out but when I try to start my computation I always get a floating point exception. After some time steps, when I restart the calculation I am able to compute again a number of time steps and so on.
This happens also with the not modified mixerGGI library.
I have no idea where the fault is. I think my boundaries are OK. Maybe my computer has just a general problem? I’ve got no idea.
Maybe someone can have a look or try to run my case with OF 1.6 extend and pimpleDyMFoam if the same error occurs?
Best wishes
Andreas
Link to the complete case: http://ubuntuone.com/0aasoEIvPToraOAPetJJie
0/U:
  |  \\    /   O peration     | Version:  1.6-ext                                 |
  FoamFile
      version     2.0;
      format      ascii;
      class       volVectorField;
      location    "0";
      object      U;
  dimensions      [0 1 -1 0 0 0 0];
  internalField      uniform (10 0 0);
  boundaryField
      outsideSlider
                  type                      ggi;
                  value                    uniform (10 0 0);
      insideSlider
                  type                      ggi;
      outlet
          type                              freestream;
                  freestreamValue            uniform (10 0 0);
      inlet
          type                              freestream;
      sides
          type                              freestream;
      ".*STL"
          type            movingWallVelocity;
          value                            uniform (0 0 0);
0/p:
  FoamFile
      version     2.0;
      format      ascii;
      class       volScalarField;
      location    "0";
      object      p;
  // density normalized pressure!!! p/rho
  dimensions      [0 2 -2 0 0 0 0];
  internalField   uniform 0;
  boundaryField
      outsideSlider
                  type                      ggi;
                  value                    uniform 0;
      insideSlider
                  type                      ggi;
                  value                    uniform 0;
      outlet
          type            freestreamPressure;
      inlet
      sides
      ".*STL"
          type            zeroGradient;
  Boundary-file:
  | \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
  |   \\  /    A nd           | Web:      www.extend-project.de                 |
  FoamFile
      version     2.0;
      format      ascii;
      class       polyBoundaryMesh;
      location    "0/polyMesh";
      object      boundary;
  24
      outlet
          type            patch;
          nFaces          1600;
          startFace       4362923;
      inlet
          type            patch;
          nFaces          1600;
          startFace       4364523;
      sides
          type            patch;
          nFaces          6400;
          startFace       4366123;
      outsideSlider
          type            ggi;
          nFaces          13632;
          startFace       4372523;
          shadowPatch     insideSlider;
          zone            outsideZone;
          bridgeOverlap   false;
      defaultFaces
          type            empty;
          nFaces          0;
          startFace       4386155;
      insideSlider
          type            ggi;
          nFaces          35144;
          startFace       4386155;
          shadowPatch     outsideSlider;
          zone            insideZone;
      m1_STL
          type            wall;
          nFaces          5880;
          startFace       4421299;
      m2_STL
          type            wall;
          nFaces          5849;
          startFace       4427179;
      m3_STL
          type            wall;
          nFaces          5849;
          startFace       4433028;
      m4_STL
          type            wall;
          nFaces          5772;
          startFace       4438877;
      m5_STL
          type            wall;
          nFaces          5849;
          startFace       4444649;
      m6_STL
          type            wall;
          nFaces          5849;
          startFace       4450498;
      m7_STL
          type            wall;
          nFaces          5772;
          startFace       4456347;
      m8_STL
          type            wall;
          nFaces          5772;
          startFace       4462119;
      m9_STL
          type            wall;
          nFaces          5801;
          startFace       4467891;
      p1_STL
          type            wall;
          nFaces          5880;
          startFace       4473692;
      p2_STL
          type            wall;
          nFaces          5849;
          startFace       4479572;
      p3_STL
          type            wall;
          nFaces          5849;
          startFace       4485421;
      p4_STL
          type            wall;
          nFaces          5772;
          startFace       4491270;
      p5_STL
          type            wall;
          nFaces          5849;
          startFace       4497042;
      p6_STL
          type            wall;
          nFaces          5849;
          startFace       4502891;
      p7_STL
          type            wall;
          nFaces          5772;
          startFace       4508740;
      p8_STL
          type            wall;
          nFaces          5772;
          startFace       4514512;
      p9_STL
          type            wall;
          nFaces          5801;
          startFace       4520284;
A.Wendy is offline   Reply With Quote
sprayEngineFoam - floating point exception error ris OpenFOAM Running, Solving & CFD 3 May 27, 2013 07:01
Error : floating point exception; overflow. maryam CFX 3 May 18, 2010 07:44
Floating Point Exception?? Alex FLUENT 2 April 21, 2009 01:29
floating point exception mojtaba CFX 2 November 15, 2008 06:58
floating point exception Mojtaba CFX 0 November 1, 2008 01:54
