Can OpenFoam do heat conduction analysis of a solid pad
Old   July 23, 2014, 21:16
Default Can OpenFoam do heat conduction analysis of a solid pad
Kan
nwpukaka is on a distinguished road
Dear OpenFoamer,
Can OpenFoam do heat conduction analysis of a solid pad?
I've solved the distributed heat flux for a boundary surface from our own CFD software, but this CFD software can't model the heat conduction of a solid part. I heard that OpenFoam can do structural analysis, but I am not sure if it can manage my task.
Thank you in advance
Kan
nwpukaka is offline   Reply With Quote
Old   July 24, 2014, 03:12
Default scalarTransportFoam or solidDisplacementFoam for conduction heat transfer
Fabian Roesler
fabian_roesler is on a distinguished road
Hi Kan
Yes, OpenFOAM can do that. The solver you are searching for is called scalarTransportFoam. A basic solver. However it also solves for convective heat transfer for a given velocity field. You have to set this U field to zero everywhere. This should do the trick. Alternatively you could use the solidDisplacementFoam. A solver for linear-elastic, small-strain deformation of a solid body, with optional thermal diffusion and thermal stresses.
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   July 25, 2014, 03:30
Kan
Originally Posted by fabian_roesler View Post
Hi Kan
Cheers
Fabian
Thank you, Fabian. This really helps
Algorithme choosing for solid part analysis of conjugate heat transfer Anna Tian Main CFD Forum 4 January 20, 2013 16:11
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Heat conduction in a solid domain Rene CFX 0 October 20, 2003 03:33
Heat conduction in a solid domain S. Balasubramanyam CFX 10 October 14, 2003 08:57
