Explicit evaluation of all the terms of momentum equation |
Andrea Ferrari
Rep Power: 17 ![]() |
Hi All,
i am using interFoam and i would like to evaluate separately the contribution of each term of the momentum equation at the end of each time-step. The first thing i am trying to check (to be sure i am calculating them correctly) if the most obvious one: if all the terms of the equation sum up to zero (or at least to something very small), but...surprisingly...they don't. What i did is: at the end of the pressure loop, just before the runTime.write() is called, i added: volVectorField sumNS = fvc::ddt(rho,U) + fvc::div(rhoPhi,U) + fvc::grad(p_rgh) - fvc::laplacian(muEff, U) -(fvc::grad(U) & fvc::grad(muEff)) - interface.sigmaK()*fvc::grad(alpha1); and then i took the volume integral of this quantity (summing up over all the cells). The results is not zero, neither something small. What i am not sure is if i am calculating all the contributions in a way that is consistent with predictor-corrector step in interFoam or maybe i just missed something in the definition of "sumNS" (gravity is set to zero, that's why the term ghf*fvc::snGrad(rho) is missing and the pressure gradient is calculated with p_rgh; also the simulation is laminar). So, should i expect a result different from zero if i calculate explicitly the sum of all the terms of the equation?...i hope the answer is no... So what i am doing wrong? Best, Andrea |
Display Modes | |
Momentum Equation used in Fluent for porous media | Sherry | FLUENT | 1 | September 12, 2016 11:22 |
Descretization of momentum equation to solve Navier stokes equation by finite volume | manishsathe14 | Main CFD Forum | 2 | December 30, 2012 23:25 |
Question on the discretization of momentum equation in icoFoam | MPJ | OpenFOAM | 3 | October 4, 2011 10:44 |
Momentum equation of Darcy's law | sambatra | OpenFOAM Running, Solving & CFD | 2 | April 17, 2009 04:27 |
Coupling between momentum and energy equation | Mattia | FLUENT | 0 | October 26, 2007 09:02 |
