Discretization of viscosity terms for non-newtonian flow:
Old   July 15, 2015, 11:50
Default Discretization of viscosity terms for non-newtonian flow:
ssherman is on a distinguished road
I'm working on a non-Newtonian flow problem, and I was interested in the difference between the treatment of the viscosity terms in nonNewtonianIcoFoam and simpleFoam:
In simpleFoam
tmp<fvVectorMatrix> laminar::divDevReff(volVectorField& U) const
    return
      - fvm::laplacian(nuEff(), U)
      - fvc::div(nuEff()*dev(T(fvc::grad(U))))
In nonNewtonianIcoFoam
- fvm::laplacian(fluid.nu(), U) - (fvc::grad(U) & fvc::grad(fluid.nu())
While my tensor skills are rusty, I believe that when incompressible these should be identical in the the continuous limit, with nnIco assuming incompressibility to 'better' resolve the viscosity gradient. However a test case seems to indicate that when the scheme of nonNewtonianIcoFoam is used in simple foam, the results are more different than the small difference I expected.
The test case is a rectangular duct, flow L to R with parabolic inlet, upper boundary symmetry, bottom stationary wall, with the fluid suddenly becoming a bingham plastic (viscosity can increase by up to 3 orders of magnitude) to the right of the white line. The flow condition is Re=10, Bi=5.0. The two attached pictures are plots of the vertical component of velocity, showing that in the default case (divDev), there exists a region of upward flow that is not observed in the nnIco case. The downward blue flow region is expected as the flow transitions from parabolic flow to plug flow in the non-newtonian region.
I don't think it's a convergence/tolerance issues, as I've worked pretty carefully to eliminate those. The fvSchemes/fvSolution file is consistent between the two cases.
Both solutions seem plausible to me, but I learn towards the divDev solution being correct
What do you all think is the best approach here? I can't really tell from the physical intuition perspective, so what is the best numerical scheme from the mathematics/numerics perspective? A more general question might be that in the newtonian laminar incompressible case, why have the divDev component at all?
Thanks!
ssherman is offline   Reply With Quote
Old   July 16, 2015, 07:57
T.D. is on a distinguished road
Hi ssherman,
It is all here:
http://www.cfd-online.com/Forums/ope...ivdevreff.html
Regards,
T.D.
T.D. is offline   Reply With Quote
rotational and inviscid Mike Main CFD Forum 40 November 9, 2023 06:03
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Divergence in Two phase flow in impeller for Cavitation joshghoun Fluent Multiphase 2 November 5, 2014 09:33
non newtonian viscosity problem moloykb FLUENT 4 July 5, 2012 15:47
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
