shallowWaterFOAM input files
Old   July 7, 2011, 04:18
Default shallowWaterFOAM input files
Tobias Liepert
tobiliepert is on a distinguished road
Hello
My question concerns the input-files needed for shwalloWaterFOAM-solver. Does anyone konw in detail the difference between files (h, h0, hTotal) . I found a presentation within the files are described as follow
h = mean surface height
h0 = deviation from the mean surface height
hTotal = free-surface
My lack of understanding: where one could define the surface (terrain). Is it possible at all? Because if I start the solver both files (h and h0) changing thier values. But the terrain surface should be time constant.
Currently I am using OpenFOAM 2.0.
tobiliepert is offline   Reply With Quote
Old   October 30, 2011, 13:48
Andreas Ruopp
andyru is on a distinguished road
Hi tobiliepert,
I'm facing the same problem. I build up a test case and h values are changing. Did you found a solution so far? I also want introduce bathymetry data or terrain data, respectively .
I would be happy, if you could share your solution!
Best regards,
Andy
andyru is offline   Reply With Quote
Old   August 31, 2016, 01:18
KUMAR CHAVAN
KUMAR7491 is on a distinguished road
I want to use shallowwaterFOAM case for tidal water simulation. In Telemac 2d, bottom surface is given as a input. In this bottom surface file is prepared by interpolating given bathymetry points at mesh nodes.
In shallowwaterFOAM I have not found any option to generate such bottom surface file and to use such bottom surface. In this case bottom surface is taken as a plane surface.
HELP ME.
KUMAR7491 is offline   Reply With Quote
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
