Calculating lift forces on various bodies
Old   August 29, 2016, 17:08
Default Calculating lift forces on various bodies
Isaac
isaac1326 is on a distinguished road
I have taken a simple model of an aircraft and successfully ran the simulation.
I have split the model into fuselage, left wing and right wing.
When I checked the forcecoeff file, it showed me one single number for lift, one single number for drag and one single number for moment.
Since I was unable to create the patch commands, my snappyhexmesh commands looks something like this...
geometry
CF.obj
type triSurfaceMesh;
name CF;
RW.obj
name RW;
LW.obj
name LW;
where CF stands for fuselage and RW stands for right wing and LW stands for left wing
isaac1326 is offline   Reply With Quote
Old   August 31, 2016, 08:30
g.freeman is on a distinguished road
geometry
CF.obj
name CF;
RW.obj
name RW;
LW.obj
name LW;
In controlDict file you need to define for each part properties of your forces coefficient, like this:
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches ( "airfoil.*" );
pName p;
UName U;
rhoName rhoInf;
log true;
liftDir (-6.98e-2 0 9.98e-1);
dragDir ( 9.98e-1 0 6.98e-2);
CofR (0.25 0 0);
pitchAxis (0 1 0);
magUInf 87.5;
rhoInf 1000;
lRef 1;
Aref 0.1;
Instead of patches you have to write CF, RW, ecc.ecc. and after that you will look lift and drag coefficients for each patch
g.freeman is offline   Reply With Quote
Old   August 31, 2016, 10:17
Isaac
Yes, I have done that, when I open the postprocessing file
It just shows me
one CL value and one CD value
This was my control Dict File
Lift forces generated by a Coanda UAV model gordonhere CFX 17 April 15, 2016 11:59
Calculating lift & drag forces in OpenFoam-2.1.0 bhups45 OpenFOAM 1 June 8, 2012 08:08
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 17:18
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
