Solidification Process : DC Casting Application |
September 20, 2016, 04:57 |
Akash
Rep Power: 11 |
Hi All
I was wondering if anybody is working on solidification process of binary alloys (Al-Mg, Al-Zn etc) using OpenFoam. My ultimate interest is to study macrosegregation (solute in-homogeneity at the scale of casting). For this I have planned a step by step procedure for development - Simple Cavity Cases: - Phase change modelling of binary alloys with lever rule with no driving forces (mentioned below). - Phase change with thermal and solutal convection. - Phase change with convection + solid globular grains nucleation and movement in the melt with appropriate drag model - Same case as above with dendritic grains. I have more or less managed to do these things but when I try to adapt the case to a DC casting case, I am having trouble in managing solute balance. I am seeing unphysical results in macrosegregation. The major difference between DC casting case (http://www.substech.com/dokuwiki/dok...ill_dc_casting) and simple cavity cases is the boundary conditions. I tried to use appropriate boundary conditions but looks like they do not work. I think the real issue is with the boundary conditions of p_rgh, Ul and Us. I am attaching these files. I hope some one has some idea on how to proceed! Cheers Akash |
September 23, 2016, 02:07 |
Rep Power: 20 |
I think you need to give a bit more information. This is a solver you programmed yourself, just giving us the boundary conditions for 3 out of many variables without a description of the domain you are trying to solve won't really help. Are you modelling this descending ram with moving meshes for example?
September 28, 2016, 07:03 |
Akash
Rep Power: 11 |
Hey
Thanks for your interest. I am unfortunately not at liberty to disclose the solver. But I will try to discuss the domain and also talk about what i am doing in the solver. I am not using moving mesh and my domain is a simple rectangle. At top, there is inflow of liquid metal and at the bottom I draw the solid at cast velocity. There is cooling from the right and symmetry on the left (its an axis symmetric case). I am attaching screenshot of the steady state solid fraction profile. In this case, I have no driving force in form of natural convection (gravity=0.0). When I activate the driving force, I am seeing really strange macrosegregation profile. Like i mentioned before, the macrosegregation with convection was done in cavity cases and well validated. Its only for this casting case I have troubles. When it comes to solver, I solve momentum equation for solid and liquid, species transport equation in solid and liquid, enthalpy equation and solid transport equation (gs transport). Cheers Akash |
December 27, 2018, 05:17 |
hey Akash , can you help me. I am new on this, I have task(simulation and macrosegregation study on DC casting) to complete it. badly, i need your help.
thank you |
April 23, 2019, 07:42 |
Hi
Sreekar Reddy S
Rep Power: 7 |
I have been trying to simulate DC Casting case lately and I am running it in a PIMLE loop. It is taking too long to get a profile, Can you help me convert it to Steady-state so that I can have a temperature profile.
I am using a little modified Solidification Master Case from (SolidificationFoam). Please Help!!! Awaiting your response. Cheers |
Error in compute process - No Active Application | yetlyg | FLUENT | 8 | October 27, 2018 22:30 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
casting solidification | peppelmb | FLUENT | 0 | September 11, 2015 08:51 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
