Point interpolation in OF
Like Tree3Likes
  • 1 Post By wyldckat
  • 1 Post By niklas
Old   January 23, 2012, 11:44
Default Point interpolation in OF
valerio
Alucard is on a distinguished road
Goodmorning
I need to perform some interpolations in Openfoam.
Imagine I've a point P(x,y) ( I know x and y) I need to find at which cell volume this point belongs and,obviously I need he cell center coordinates via the .x() and .y() functions.
All this because I need to know the vector position difference between the point P and the cell center
Xdiff=X(c)-X(P)
(X is a vector)
that I'll use later for some interpolations.
Does some clever function exist in OpenFOAM??
I'm surfing in the *.C,*.H openfoam files and I'm reading the forum since four days without success .
Alucard is offline   Reply With Quote
Old   January 23, 2012, 15:18
Retired Super Moderator
Bruno Santos
Hi Valério,
I'm not sure how this can be used, but "Foam::interpolation" seems to be the core of what you need: http://foam.sourceforge.net/docs/cpp/a00905.html
For even more information: http://openfoamwiki.net/index.php/In...%28OpenFOAM%29
Best regards and good luck!
Bruno
elvis likes this.
Old   January 24, 2012, 05:07
valerio
Originally Posted by wyldckat View Post
Hi Valério,
Bruno
Hi Bruno
thank you very much I'm reading all of it!
I've to be honest for the moment I didn't figure out how to do it (I understand what OF inteprolation functions do but I didn't understand how to pass them my P point yet)
I have a square domain and a regular mesh so as I know how to obtain the center of a cell I could do it writing a "function" by myself (I come from Fortran and I was used to code everything by myself).
But I think in my lab they will continue to use the software I'm developping also after i'll leave that's why I'm try to get a "gereral" and efficient way that could works for more general domain shapes and unstructured meshes.
Old   January 24, 2012, 05:57
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
check this thread
http://www.cfd-online.com/Forums/ope...rpolation.html
niklas is offline   Reply With Quote
Old   January 24, 2012, 10:23
valerio
Originally Posted by niklas View Post
hi Niklas thank you
I tried to copy/paste the part:
   dictionary interpolationDict = mesh.solutionDict().subDict("interpolationSchemes");
    autoPtr<interpolation<vector> > Uinterp = interpolation<vector>::New(interpolationDict, U);
    vector pos(0,0,0);
    label cellI = mesh.findCell(pos);
    vector Ui = Uinterp->interpolate(pos, cellI);
just to see if it is compiled but no. The first line it's ok but for the second one i have:
In file included from interFoam.C:88:
miha.H: In function ‘int main(int, char**)’:
miha.H:160: error: ‘interpolation’ was not declared in this scope
miha.H:160: error: template argument 1 is invalid
miha.H:160: error: expected unqualified-id before ‘>’ token
If I have well understood:
-the first line look in the dictionary to see what kind of interpolation scheme I've chosen.
-the second one just says that I'll interpolate U and Uinterp is the pointer
-in the third one there is the vector position X
-in the fourth one I find the index (label) of the cell that belongs X
-in the fifth I obtain the interpolated value of the U field in the X point.
So if I just tailor these lines and I copy them in my "main" i have:
    autoPtr<interpolation<vector> > aplhainterp = interpolation<vector>::New(interpolationDict, alpha1);
    vector pos(0,0,0);
    scalar alphaint = alphainterp->interpolate(pos, cellI);
I was also looking to:
http://www.cfd-online.com/Forums/ope...onsistent.html
interpolationCellPoint<vector> UInt(U);
point p1(0.0550,0.0048,0.0001);
Info << "p1=" << UInt.interpolate(p1,meshPhys.findCell(p1)) << endl;
I tried to but I have compilation errors.
I'm sorry for the stupid questions but I'm still learning C++ and undesrtand in few months how Openfoam works is quite difficult for me cause there is no a clear programmer's guide about those things and I also have some problems in beeing confident with the C++ syntax.
Thank you!
Old   January 24, 2012, 11:50
niklas's Avatar
Niklas Nordin
you need to include interpolation.H.
add the line below at the top of includes
#include "interpolation.H"
Old   January 24, 2012, 12:33
valerio
Thank you, i was thinking about the same thing "I've to include somehow it or it's already included in some other .H files?" you give me the right answer.
so now this part
//   dictionary interpolationDict = mesh.solutionDict().subDict("interpolationSchemes");
autoPtr<interpolation<scalar> > alphaint =interpolation<scalar>::New(interpolationDict,
alpha1);
vector pos(0,0,0);
scalar alphai = alphaint->interpolate(pos, cellI);
gives me back at each time step the value of alphai in the point (0,0,0).
It's a good start thank you very much.
Now the second part (i've to develop) is to store several "position vectors" at each time step and for each of the points of them perform the interpolation step.
I hope I could ask all of you some support if I still have some problem!
thank you very much
Sincerely
Valerio
Old   January 24, 2012, 13:34
niklas's Avatar
Niklas Nordin
easiest way is to read them from a dictionary
stick this at the end of createFields.H
    IOdictionary myDict
        IOobject
            "myOwnDict",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
    vectorList positions(myDict.lookup("positions"));
then you create the file myOwnDict and put it in the constant directory.
Easiest way is to copy one of the other files in the constant directory and
then delete everything below the FoamFile{...} header
then you just add the list of vectors to the positions, like this
positions
    (0 0 0)
    (1 1 1)
done.
Old   January 25, 2012, 17:40
valerio
[/code]done.
Hi again
thank you for the idea but in my case points change during time I'll show you the part of my code because still have a problem:
forAll (mesh.cellCentres(),cellI)
    if(alpha1[cellI]<0.95 && alpha1[cellI]>0.5)
     double X_p=mesh.cellCentres()[cellI].x();
     double Y_p=mesh.cellCentres()[cellI].y();
     double N_x=nHat[cellI].x();
     double N_y=nHat[cellI].y();
     double X_ext=X_p+N_x;
     double Y_ext=Y_p+N_y;
     double X_int=X_p+N_x;
     double Y_int=Y_p+N_y;
     vector pos_int(X_int,Y_int,0.);
     vector pos_ext(X_ext,Y_ext,0.);
     autoPtr<interpolation<scalar>> Cl_int = interpolation<scalar>::New(interpolationDict, Cl);
     label cellJ = mesh.findCell(pos_int);
     scalar Clint = Cl_int->interpolate(pos_int, cellJ);
     autoPtr<interpolation<scalar>> Cl_ext = interpolation<scalar>::New(interpolationDict, Cl);
     label cellK = mesh.findCell(pos_ext);
     scalar Clext = Cl_ext->interpolate(pos_ext, cellK);
The idea is to obtain for each point selected by the "if" statement, the difference "Clext-Clint". The part of the code I wrote is just a "structure" the way I obtain the Xext and Yint is not exactly like this (you add to the X_p a vector proportional to the local normal, in the code for te moment it's just "n" without the scale factor but it's just a simple test.
Cl is the liquid concentration and it's just a scalar field (like apha1)
So the problem is that if I write something like
for only one point outside the "forAll" loop I compile it if I put (this is the case) In a Loop I've compilation errors.
Do you perhaps know where I fail? I'm so close to the end: if this part works I'm happy cause all the rest of the code is already working
Thank you very much!
Valerio
Old   January 26, 2012, 01:52
niklas's Avatar
Niklas Nordin
Why do you recreate the dictionary and interpolator every time.
I think you have misunderstood how the interpolator works.
You only need to create it once and then give the position and cell number to get the interpolated value
of the field used in the second argument of the New-call below.
// interpolator for the alphaField
autoPtr<interpolation<scalar>> alphaInterpolator = interpolation<scalar>::New(interpolationDict, alpha1);
         //double X_p=mesh.cellCentres()[cellI].x();
         //double Y_p=mesh.cellCentres()[cellI].y();
         vector p = mesh.cellCentres()[celli];
         //double N_x=nHat[cellI].x();
         //double N_y=nHat[cellI].y();
         vector N = nHat[celli];
         //double X_ext=X_p+N_x;
         //double Y_ext=Y_p+N_y;
         vector Pext = p + N;
         //double X_int=X_p+N_x;
         //double Y_int=Y_p+N_y;
         vector Pint = p + N; // this seems to be the same as Pext?!?!
         vector pos_int(Pint.x(),Pint.y(),0.);
         vector pos_ext(Pext.x(),Pext.y(),0.);
         scalar Clint = alphaInterpolator->interpolate(pos_int, cellJ);
         scalar Clext = alphaInterpolator->interpolate(pos_ext, cellK);
Tobi likes this.
Old   January 26, 2012, 12:22
valerio
Thank you very much it works now!
Your help was really important to me!
As I'll finish all the modifications and the code will work I'll show you the results!
Old   March 30, 2012, 09:45
valerio
Goodmorning again to everybody.
I have now a "new" problem unfortunately.
The subroutine I wrote (thanks a lot Niklas for your precious help), actually works fine in serial mode.
As I try to run it in parallel i have a "bug" when, moving from a "p" point located in one subdomain, I obtain a Pext (or Pint) point that lies outside.
I read (Ref1) that mesh.findCell doesn't "connect" different subdomains and i really don't find the "way" to solve this problem cause I've not good ideas about how can I "connect" them in parallel. i tried reading some infos about parallel programming in openFOAM (Ref.2) cause I'm really new at it.
I hope Niklas you can help me (it's you again in ref.2)
Thank you very much.
(Ref.1 http://www.cfd-online.com/Forums/ope...ordinates.html)
(Ref.2
http://www.cfd-online.com/Forums/ope...allel-run.html)
Old   December 13, 2013, 13:28
ooo
ooo is on a distinguished road
Do you know how we can interpolate in a reverse way, i.e interpolate(distribute) a vector, to a volVectorField?
e.g consider we have a volVectorField U. Now i have some vectors and i would like to interpolate(distribute) their values to the existed volVectorField.
(I tried to use pointVolInterpolation but it seems that it does not exist in OpenFOAM anymore. The file cannot be found in http://www.openfoam.org/docs/cpp/. Also using it in code, gives me error (there isn"t any pointVolInterpolation.H , also it has not been declared in Interpolation.H as well)
Also do you know the difference between the accuracy of cellPoint and cellPointFace scheme?
Thanks in advance.
ooo is offline   Reply With Quote
Old   December 29, 2013, 20:10
Bruno Santos
Greetings to all!
Mmm... isn't opposite operation named "reconstruct" in OpenFOAM? You can check the following project for ideas on how this is done: https://github.com/wyldckat/reconstr...te-fields/wiki
Answered here: http://www.cfd-online.com/Forums/ope...tml#post468049 post #5 - the quick answer:
The correct class name should be "volPointInterpolation".
Well... I think it all really depends on where you want to interpolate and what field.
Because the "cellPointFace" scheme will take into account the values at the centre of the cell, the nearest points and the nearest centres of cell faces; the problem is whether the values at the face centres are already interpolated results or are they values in the surface mesh (where there is no other cell on the other side of the face). In other words, it really depends on whether there are already too many interpolated values in the neighbourhood.
Best regards,
Bruno
ooo likes this.
Old   October 5, 2016, 13:40
Default cellPoint interpolation at boundaries
  #15
Praveen Srikanth
praveensrikanth91 is on a distinguished road
I am trying to define a new boundary condition for a fluid-fluid interface in chtMultiRegionFoam to which I have added phase change. I want to get the temperature at the interface and to do that I want to interpolate the temperatures from the cell center values to the interface from both sides and average them. I know that the cellPointFace interpolation uses prescribed boundary values at these faces which turns out to be a default value. I was wondering How does the cellPoint interpolation work at boundaries if I give it the face center of the boundary faces as the position vector? I tried to go through the code for clues but I do not see any specific treatment at boundaries. Does that mean that it would interpolate values at the boundary?
Any information would be appreciated
Thanks
Praveen
praveensrikanth91 is offline   Reply With Quote
Face and point ordering during interpolation Arnoldinho OpenFOAM Programming & Development 1 November 29, 2011 04:54
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
