CompressibleInterDyMFoam with 6DOF body
Old   January 27, 2017, 14:55
Default CompressibleInterDyMFoam with 6DOF body
Leonard Cassady
im_lenny is on a distinguished road
I'm trying to determine how to best simulate a large object hanging by a cable under water. The goal is to prescribe the motion of the top of the cable and simulate the motion of the large object as it moves through the water. The motion of the object will be large compared to the domain (20% of the length), so I worry about the mesh. Is it possible to set up a case that occasionally re-meshes as time goes on, or will the dynamic mesh be able to handle it.
My object is a complicated .stl. I normally use snappyhexmesh to generate 3D volume mesh with about 10 million cells. Is it possible to use snappy or do I need to switch to overset grids?
Can I prescribe the motion of the upper end of the cable? Maybe making the cable a very stiff spring and moving the upper end is an option?
I am running OpenFoam version 3.0, but I am willing to upgrade to version 4.1.
Regards,
Lenny
im_lenny is offline   Reply With Quote
Old   July 17, 2017, 09:15
Default flexible cable
rezataheri
r.taheri is on a distinguished road
hi dear
My model is a body floating in water that with flexible cables anchored.
Can OpenFoam software do the modeling of flexible cables and their transformations?
help me please
r.taheri is offline   Reply With Quote
Old   July 17, 2017, 09:33
Leonard Cassady
OpenFOAM does not model cables.
Old   July 19, 2017, 04:26
Default Mooring Line
G Grewal
gsg001 is on a distinguished road
Hi Leonard and Reza,
Waves2foam has added the ability to model mooring lines 3 months ago.
https://github.com/ogoe/waves2Foam/t...es2FoamMooring
gsg001 is offline   Reply With Quote
Old   July 19, 2017, 08:40
Default appreciation
rezataheri
hi sir
thank you for this gaide.
good luck
6dof, compressibleinterdymfoam, openfoam
6dof model - floating body flinde FLUENT 13 March 6, 2021 14:32
Issues with 6DoF body alexvaleije OpenFOAM Running, Solving & CFD 0 March 15, 2016 07:26
Dynamic mesh for a body in a flow (6DOF solver) supermanks FLUENT 2 January 10, 2016 21:16
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 07:26
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
