Error in LRR (RAS) model in OpenFOAM v4.1
Like Tree3Likes
  • 1 Post By Inquisitor101
  • 1 Post By cryabroad
  • 1 Post By Ellen Caroline
Old   February 8, 2017, 18:32
Default Error in LRR (RAS) model in OpenFOAM v4.1
Inquisitor101's Avatar
Edmond
Inquisitor101 is on a distinguished road
I was trying some simple tutorial about a backward-facing step in steady state via different turbulence models in RAS using the simpleFoam solver. One of which was the LRR (Reynolds stress model). The tutorials themselves were done so in another version of OpenFOAM and the one I am using was the latest version: 4.1.
All else worked splendidly, however in the case of the LRR, I keep getting an error returned from the fvSchemes file. Basically, the steps in this method that I am following are: after copying the kEpsilon file (by file I mean the whole kEpsilon simulation folder -- i.e. the directory containing: 0/ constant/ system/ ), I execute the command:
simpleFoam -postProcess -func R
I get, instead of the expected R file, a file named turbulenceProperties:R in the 0/ directory. Moving on, I rename it to R.
Next, I change the turbulence model from kEpsilon to LRR as intended. Afterwards, I edit the fvSchemes and include the following for the divergence terms:
divSchemes
    default             none;
    div(phi,U)         bounded Gauss linearUpwind grad(U);
    div(phi,k)          bounded Gauss linearUpwind grad(k);
    div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon);
    div(phi,omega)  bounded Gauss limitedLinear 1;
    div(phi,v2)        bounded Gauss limitedLinear 1;
    div(phi,R)         bounded Gauss upwind;
    div(R)              Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
    div(nonlinearStress)             Gauss linear;
Then, after running the command simpleFoam, I get the following error:
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field "(k|epsilon|omega|f|v2|R)"     tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model LRR
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/username/OpenFOAM/username-4.1/run/tutorials/incompressible/simpleFoam/bfs/BFS_baseCase/0/R at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 72.
FOAM exiting
Then, after trying different stuff, I came up with the following and it worked. I simply change the default condition (in the divSchemes) from a none into some other scheme (e.g. Gauss linear) and all worked splendid.
My question hence is why did this happen? is there anything wrong with my implementation or is it a bug ?
Thanks !
lpz456 likes this.
Inquisitor101 is offline   Reply With Quote
Old   July 29, 2018, 22:28
Ruiyan Chen
cryabroad is on a distinguished road
Take a look at this thread
fvSchemes
According to Dr. Jasak, "It does not recognise it because this is a straightforward div(thing) term and not convection div(phi, thing). Therefore you cannot do upwinding, since there's no flux to decide the direction from."
lpz456 likes this.
cryabroad is offline   Reply With Quote
Old   July 2, 2020, 15:09
Giacomo Del Bianco
Giacomodb is on a distinguished road
Thank you very much!! You fixed my problem.
I saw browsing from the internet but I didn't realized it was different from the one:
Later I got another error:
keyword wallDist is undefined in dictionary
I googled it and i added at the end of fvSolutions the following definition:
wallDist
    method meshWave;
Then it worked fine!
Thank you very much again!!
Giacomo
Giacomodb is offline   Reply With Quote
Old   March 1, 2022, 09:39
SunTime
lpz456 is on a distinguished road
divSchemes
    default             none;
Create time
Reading field p
Reading field U
cannot find file
FOAM exiting
Thanks !
Hi,I was using LRR model to simulate pitzDaily by simpleFoam solver, but the results are unsteay, have you meet the same question?
lpz456 is offline   Reply With Quote
Old   November 29, 2023, 14:11
Ellen Caroline
Ellen Caroline is on a distinguished road
divSchemes
    default             none;
Create time
Reading field p
Reading field U
cannot find file
FOAM exiting
Thanks !
Is it possible to create a R file if I didn't use the command "- postProcess - func R"? My simulation is already done and a I just typed "twoPhaseEulerFoam" in the terminal to initialize it.
lpz456 likes this.
Ellen Caroline is offline   Reply With Quote
fvschemes, openfoam4.0, ras
Simulating an aether model of EM using OpenFoam? lamare Electromagnetics 2 September 15, 2016 05:08
Prandtl's one-equation RAS turbulence model Djub OpenFOAM Running, Solving & CFD 3 April 9, 2016 06:30
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 10:24
