decomposePar number of processors issue
Old   February 27, 2017, 18:14
Default decomposePar number of processors issue
Ewan
EFRENCH is on a distinguished road
Hi all,
I have got my simulation running fine using the 16 processors that the solver I am using was initially writing for. However, I am trying to update the solver to use 32 processors. So far I have changed the Allrun, run_mpi and decomposeparDict files to include the new figure of 32 but when I try to run a simulation that was working, I now get the error file attached below! I have looked all through my directory for things to change but feel I have done everything.
The solver uses the scotch decompose method just for convenience so I don't think I need to touch that at all. If someone might be able to throw me over some suggestions it'd be much appreciated!
EFRENCH is offline   Reply With Quote
Old   March 1, 2017, 08:47
Joachim Herb
jherb is on a distinguished road
Did you run decomposePar (after you changed the settings in decomposeParDict)?
jherb is offline   Reply With Quote
Old   March 1, 2017, 09:28
Ewan
Hi jherb,
Yes I did. It seems to be functioning some of the times but not others! Regardless though, they all the simulations I run seem to start at the last time step of my previous simulation (40285 rather than 0) even when I have removed the postProcessing folder and all other files relating to the previous runs! My controlDict is set to run from firstTime etc. Very confusing.
Old   March 2, 2017, 17:19
Joachim Herb
This is a complete shot in the dark, but: Have you checked that all your cluster node (I assume you use a cluster if you use 32 processes) see the same file system and it is working correctly? Can you log into the nodes with ssh and check this?
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
AMI interDyMFoam for mixer danny123 OpenFOAM Running, Solving & CFD 4 June 19, 2013 04:49
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
