Starting With A Detonation Wave
Old   March 6, 2017, 22:10
Default Starting With A Detonation Wave
Robert Huang
HRobertHS is on a distinguished road
Hi OpenFOAM,
I am trying to simulate the combustion of an engine using OpenFOAM in a rotating cylinder using a detonation wave. The detonation wave is supposed to rotate around the cylinder; however, how do I start with the detonation wave then allow it to rotate? Additionally, how am I supposed to calculate Thrust and Mass Flow rate from injectors to calculate specific impulse?
My Mesh is below:
Any help would be appreciated!
Thanks,
HRobertHS
HRobertHS is offline   Reply With Quote
Old   March 8, 2017, 15:25
Robert Huang
bump...........
Old   March 8, 2017, 15:29
Robert Huang
I am also having a problem with doing a test run without the detonation wave, and I am getting the error
Cannot find patchField entry for Outlet
file: /home/robert/OpenFOAM/robert-v1612+/run/tutorials/incompressible/icoFoam/test/0/p.boundaryField from line 18 to line 18.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
FOAM exiting
I am using reactingParcelFoam. I am trying to simulate a rotational detonation engine. The files are listed below here:
https://www.dropbox.com/s/4kh5wkdsde...im.tar.gz?dl=0 since I cannot upload them as they exceed file size.
Any help?
how to model shock wave generated from detonation? Maddy FLUENT 13 August 31, 2020 08:18
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 04:59
detonation wave simulation Krish FLUENT 15 February 7, 2017 12:38
IHFOAM - Wave generation with moving boundaries Phicau OpenFOAM Verification & Validation 0 May 18, 2015 04:53
