May 9, 2017, 05:12 |
How to test openfoam benchmark ?
Zhaotianxing
Rep Power: 9 |
Please tell me how to test openfoam parallel benchmark on linux cluster? Which case is suitable to do it ? cavity of icofoam or dambreak of interfoam ? Because when i test openfoam benchmark on linux with interfoam solver , I change the cells to this :
blocks ( hex (0 1 5 4 12 13 17 16) (92 32 2) simpleGrading (1 1 1) hex (2 3 7 6 14 15 19 18) (76 32 2) simpleGrading (1 1 1) hex (4 5 9 8 16 17 21 20) (92 168 2) simpleGrading (1 1 1) hex (5 6 10 9 17 18 22 21) (16 168 2) simpleGrading (1 1 1) hex (6 7 11 10 18 19 23 22) (76 168 2) simpleGrading (1 1 1) ); But ,when I test with 56cores ,the test time is shortest . When I go on increasing the cpu cores ,the test time will become longer! I want to konw how to test openfoam benchmark with the right way so that I can obtian the test results like this : http://www.hpcadvisorycouncil.com/pd...e_Analysis.pdf |
May 15, 2017, 23:36 |
Taher Chegini
Rep Power: 12 |
I have found a paper that explains the process with details:
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA612337 You can try to setup similar cases. |
May 16, 2017, 18:13 |
Tobias Holzmann
Rep Power: 51 |
A benchmark of scaling should be done with a large case. Imagine you have a testcase with 20.000 cells and a normal one phase solver. There is finally not much to calculate and using 10 cores would slow down the whole simulation because each processor is waiting for the other one's information. I have in mind that you should have round about 10.000 to 30.000 per CPU. However, it also depends highly on the problem you want to solve and the corresponding model. Other impacts on the speed:
Keep foaming, Tobias Holzmann |
August 10, 2017, 23:32 |
Zhaotianxing
Rep Power: 9 |
thanks a lot , i will read it carefully to find the solutions.
August 10, 2017, 23:43 |
#5 | |
Zhaotianxing
Rep Power: 9 |
thanks a lot ,I will find a proper sample to test benchmark of openfoam. |
August 10, 2017, 23:45 |
#6 | |
Zhaotianxing
Rep Power: 9 |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 09:55 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 22:44 |
A new test harness for OpenFOAM | mbeaudoin | OpenFOAM Announcements from Other Sources | 0 | June 17, 2010 10:36 |
