Minimum Signed Distance from .stl file
Old   August 21, 2012, 09:53
Default Minimum Signed Distance from .stl file
Wichard Sullwald
Wichard is on a distinguished road
Hello everyone
I am brand new to both openFoam and the CFD-online comunity, so please bear with me if my questions are a bit simple.
I am working on interface tracking for capturing the grain regression of SRM's using LSM. given an initial .stl file how will I go about generating a minimum signed distance (MSD) function around this geometry?
I have implemented an analytical method in Matlab where for each face (triangle) in the stl file I calculate the distance to each each grid point and so build up the MSD. This is an extremely cumbersome method, made slightly more elegant by excluding gridpoints from the calculation by checking if they are closer to neighbouring faces using exclusion planes. It remains a very un effecient method.
Another Idea was to use the Fast Marching Method to build the MSD, this would however require that all the gridpoints neighbouring the surface be initialized, and how to locate them is a bit lost on me.
Any help, Ideas, or Advice would be much apreciated!
Wichard is offline   Reply With Quote
Old   June 12, 2017, 15:04
Pavan
pvpnrao is on a distinguished road
were you able to solve your problem. Can you share the details
pvpnrao is offline   Reply With Quote
fmm, lsm, msd
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
