differences between 1812 and V6
Like Tree3Likes
  • 2 Post By wyldckat
  • 1 Post By Daniel_Khazaei
Old   February 6, 2019, 11:11
Default differences between 1812 and V6
pici's Avatar
Pierluigi Cirrottola
pici is on a distinguished road
Hi to everybody.
I'm downloading just now the latest release of openFOAM, but I have a Hamlet's trouble:
wich kind of difference we can found between V1812(from openfoam.com) and V6(from openfoam.org)?
Thank you very much for your replies
Bye,
Piero
pici is offline   Reply With Quote
Old   February 6, 2019, 18:44
Retired Super Moderator
Bruno Santos
Quick answer:
  1. Go to this page: https://openfoamwiki.net/index.php/Main_Page
  2. On the top right corner you can see several links to the release notes for each version.
  3. Check the release notes for all versions of OpenFOAM+ (it refers to openfoam.com) and check the information that they provide for each version.
  4. Essentially the majority of the new features that OpenFOAM+ (OpenFOAM.com) has got, are not present in OpenFOAM (OpenFOAM.org)
Daniel_Khazaei and RobertHB like this.
Old   February 7, 2019, 06:20
pici's Avatar
Thank you very much.
So, because I'm using Ubuntu 18.04, if I want use v1812, I have to install it from source.
Well, I will try to do this.
Just another question, about Paraview 5.6: is it better to build it by source (in ThirdParty-v1812.tgz) , or can be used the pre-compiled version instead?
Thank you very much again
Old   February 7, 2019, 12:00
Daniel
Daniel_Khazaei will become famous soon enough
you can follow the instruction provided by the wiki:
https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04
Just change 1806 to 1812 when executing each step and you should be fine.
If you have decided to build Paraview, make sure you have xmlpatterns installed for qt5:
sudo apt install libqt5xmlpatterns5 libqt5xmlpatterns5-dev qtxmlpatterns5-dev-tools
Paraview will successfully install even without it but an error "could not exec xmlpattern" pops up during compile of Paraview and OpenFOAM's Paraview reader.
wyldckat likes this.
Daniel_Khazaei is offline   Reply With Quote
