The problem of bed load transport rate based on FE3.2-famesh
Old   March 12, 2018, 23:48
Smile The problem of bed load transport rate based on FE3.2-famesh
LXJ
liuxiaojian2015 is on a distinguished road
when i calculated the bed load transport rate (qbi=q0*τ/τi - C*|q0|dη/dxi) component in the i direction by using OpenFOAM famesh, i found the result of dη/dxi in two sides in y direction (two sides patch: symmetryPlane) is wrong by simulating the scour of pileline under current and using five layer grids. The result show the value is zero in internal face ceters in y direction, however it is very big in two sides. Please help me if someone know how to slove it. Thank you.
The code:
//########################### bed load transport rate ###########################//
hA=mesh.boundaryField()[patchID].faceCentres.z();
edgeScalarField absWLEdge = fac::interpolate(hA);
areaVectorField gha = fac::edgeIntegrate(absWLEdge.mesh().Le() * absWLEdge);
// or //areaVectorField gha = fac::grad(hA);
areaVectorField qbA = q0A*shearN - 1.5 * mag(q0A) * gha;
Best,
LXJ
liuxiaojian2015 is offline   Reply With Quote
Old   March 13, 2018, 05:01
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by liuxiaojian2015 View Post
The code:
Best,
LXJ
Which are your bc's for velocity in the spanwise direction?
Santiago is offline   Reply With Quote
Old   March 13, 2018, 05:08
LXJ
Hi Santiago,
Yes, you are right. The spanwise direction (i.e., x direction) is set as the velocity direction. Two sides are perpendicular to y direction, and parallel to x direction.
Best,
Liu
Old   March 13, 2018, 05:10
Hi Santiago,
Best,
Liu
Ok,
Two questions:
1. Which Boundary conditions you set for velocity in the domain?
2. Do you start your simulation from a solution obtained by not moving the grid/potential?
Old   March 13, 2018, 05:31
Smile
LXJ
Ok,
Two questions:
Hi, Santiago
Thank you for you reply. First, in order to explain this answer, i show a picture for the detailed model setup (plese ignore my clumsy drawing, ), the Boundary conditions for the velocity is set in the left side of model. Second, i attempted the simulation by not moving the mesh motion, the result of grad(hA).y() is acquired in such condition and it is showed again in the attachment.
Best,
Liu
Old   March 13, 2018, 05:41
Smile
LXJ
Ok,
Two questions:
I also attempted the simulation by not considering the current velocity, i.e., i set the velocity is about zero. This value will not induce the sediment transport. Thus, no bad results were showed.
Old   March 13, 2018, 06:05
Smile
LXJ
Ok,
Two questions:
I am so sorry to trouble you again. I give a error introdution several minutes ago. When i use the smaller current velocity, the bed surface gradient is also wrong, please see the attachment. The error also exist in the patch junction. Is this indicate the fac::grad() is wrong in patch junction?
I need emphasize the gha.x() and gha.z() keep same variation for the five layer mesh. Just gha.y() show the error. Thank you.
File Type: jpg grad(hA).y()----small current velocity.jpg (57.3 KB, 13 views)
Species transport model problem argeus FLUENT 8 September 20, 2019 07:23
Fixed Bed Gasifier, Species Transport Problem therandomestname FLUENT 12 January 4, 2019 07:08
Multiphase liquid-solid spouted bed: pressure problem ghost82 FLUENT 7 November 10, 2013 12:12
Specifying volume/Mass fraction in Species Transport for problem without inlet tanjinjack FLUENT 1 October 9, 2011 04:42
moving load problem aditi chauhan ANSYS 0 October 9, 2010 04:47
