How to convert boundaryField into "double" floating point? |
April 14, 2018, 21:05 |
yehanyu
Hello everybody,
I am recently working on modifying the compressible solver "rhoCentralFoam". Here I want to retrieve the boundary field of "e" and "p", then substitute them into a user-defined function named "ep_d", then assigned the result to the boundary field "rho". ... p.correctBoundaryConditions(); forAll(rho.boundaryField(),i) { rho.boundaryField()[i] = pp.ep_d(e.boundaryField()[i], p.boundaryField()[i]); } runTime.write(); ... However I got a compilation error: nistCentralFoam.C: In function ‘int main(int, char**)’: nistCentralFoam.C:248:85: error: no matching function for call to ‘phys_property::ep_d(Foam::fvPatchField<double>&, Foam::fvPatchField<double>&)’ rho.boundaryField()[i] = pp.ep_d(e.boundaryField()[i], p.boundaryField()[i]); ^ In file included from nistCentralFoam.C:46:0: property.H:248:6: note: candidate: double phys_property::ep_d(double, double) REAL phys_property::ep_d(REAL e, REAL p) ^ property.H:248:6: note: no known conversion for argument 1 from ‘Foam::fvPatchField<double>’ to ‘double’ So what is the solution? Thank you very much. |
April 17, 2018, 00:34 |
Adhiraj
Will this work:
forAll(rho.boundaryField(), patchI) { fvPatchScalarField& rhoPatch = rho.boundaryField()[patchI]; fvPatchScalarField& ePatch = e.boundaryField()[patchI]; fvPatchScalarField& pPatch = p.boundaryField()[patchI]; forAll(pPatch, faceI) { const scalar ei = ePatch[faceI]; const scalar pi = pPatch[faceI]; rhoPatch[faceI] = pp.ep_d(ei, pi); } } |
April 17, 2018, 20:21 |
#3 | |
yehanyu
boundaryfield, rhocentralfoam |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 06:57 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
pimpleDyMFoam constantly giving floating point exception and solution divergence | fedvasu | OpenFOAM Running, Solving & CFD | 0 | November 28, 2013 00:53 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
