Courant Number blows up after several time steps at watersurface |
July 30, 2018, 07:27 |
Christian Jähnel
Rep Power: 9 |
Hallo Foamers,
I am simulating an vortex power plant with interDyMFoam with AMI and an steady and a rotating mesh. As turbulence model I use SpalartAlmares IDDES After several seconds of smooth simulating the Courant number blows up and the simulation fails. When I look in the latest results I have a few cells (at the water surface, close to the turbine) with velocity magnitudes higher than 1000m/s, which are obviously the problem. The cells and the mesh look quite okay, as I would say. This problem occurs in different meshes at different timesteps. Mostly I can start the simulation at an earlier timestep and it runs through the problematic timestep. Here are some pictures and my boundary conditions. U-file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { top { type pressureInletOutletVelocity; value uniform (0 0 0); } inlet { type variableHeightFlowRateInletVelocity; flowRate 0.701; alpha alpha.water; value uniform (0 0 0); } outlet.water { type fixedValue; value uniform (0 0 0); } outlet.air { type zeroGradient; } SohleOW { type fixedValue; value uniform (0 0 0); } SohleUW { type fixedValue; value uniform (0 0 0); } SohleWS { type fixedValue; value uniform (0 0 0); } WaendeOW { type fixedValue; value uniform (0 0 0); } WaendeUW { type fixedValue; value uniform (0 0 0); } WSBecken { type fixedValue; value uniform (0 0 0); } turbine { type movingWallVelocity; value uniform (0 0 0); } AMI1 { type cyclicAMI; value uniform (0 0 0); } AMI2 { type cyclicAMI; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { top { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } inlet { type zeroGradient; } outlet.water { type zeroGradient; } outlet.air { type totalPressure; rho rho; psi none; gamma 1; p0 uniform 0; value uniform 0; } SohleOW { type zeroGradient; } SohleUW { type zeroGradient; } SohleWS { type zeroGradient; } WaendeOW { type zeroGradient; } WaendeUW { type zeroGradient; } WSBecken { type zeroGradient; } turbine { type zeroGradient; } AMI1 { type cyclicAMI; value uniform 0; } AMI2 { type cyclicAMI; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh solidBodyMotionFvMesh; motionSolverLibs ( "libfvMotionSolvers.so" ); solidBodyMotionFvMeshCoeffs { cellZone rotating; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin (7.98 2.15 0.9); axis (0 0 1); omega -2.5447; // 5 rad/s } } // ************************************************************************* // Christian |
August 1, 2018, 12:57 |
Joaquín Neira
Rep Power: 8 |
I don't know what may be the cause of this, but you can try adding
adjustTimeStep true; maxCo <number less than 1>; |
August 1, 2018, 15:17 |
Honza Höll
Rep Power: 10 |
Hi, I had similar problem with interFoam. You should use bounding for gradU in fvSchemes, there is topic about it. Definitely use adjustTimestep and Co less then 1. For VOF computations Co less than 0.1 is recommended but it depends on mesh size and cells volume ratio.
August 2, 2018, 02:32 |
Robert
Rep Power: 11 |
Furthermore, try to run a checkMesh. If you get to many errors or skewed cells, it's likely that your mesh is the cause for your problems.
If you liked my answer to your question, please consider leaving a "Like" in return |
August 2, 2018, 08:26 |
Christian Jähnel
Rep Power: 9 |
Thank you for your replies.
here is my checkMesh: Code:
Create time Create polyMesh for time = constant Time = constant Mesh stats points: 12571351 faces: 32443085 internal faces: 29757718 cells: 10044785 faces per cell: 6.19235 boundary patches: 13 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 8616751 prisms: 235466 wedges: 0 pyramids: 0 tet wedges: 671 tetrahedra: 24 polyhedra: 1191873 Breakdown of polyhedra by number of faces: faces number of cells 4 210236 5 144169 6 207571 7 224 8 230 9 422636 10 19 11 4 12 132870 13 2 15 73092 18 820 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "constant/cellToRegion" <<Writing region 0 with 3814383 cells to cellSet region0 <<Writing region 1 with 6230402 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology top 33807 35382 ok (non-closed singly connected) inlet 1212 1361 ok (non-closed singly connected) outlet.water 482 586 ok (non-closed singly connected) outlet.air 558 639 ok (non-closed singly connected) SohleOW 16892 17262 ok (non-closed singly connected) SohleUW 13280 13603 ok (non-closed singly connected) SohleWS 459719 466049 ok (non-closed singly connected) WaendeOW 26801 27627 ok (non-closed singly connected) WaendeUW 16280 16974 ok (non-closed singly connected) WSBecken 133829 135355 ok (non-closed singly connected) turbine 1267887 1480133 ok (closed singly connected) AMI1 357310 358590 ok (closed singly connected) AMI2 357310 358590 ok (closed singly connected) Checking geometry... Overall domain bounding box (0 0.27509 0.100001) (15 4.41 2.3) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.70651e-16 1.27318e-16 -2.97151e-13) OK. Max cell openness = 4.24293e-16 OK. Max aspect ratio = 12.0035 OK. Minimum face area = 1.25745e-08. Maximum face area = 0.00741749. Face area magnitudes OK. Min volume = 6.17915e-10. Max volume = 0.000250245. Total volume = 41.298. Cell volumes OK. Mesh non-orthogonality Max: 78.2713 average: 10.0852 *Number of severely non-orthogonal (> 70 degrees) faces: 4. Non-orthogonality check OK. <<Writing 4 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 5.36521, 117 highly skew faces detected which may impair the quality of the results <<Writing 117 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. Indeed there are a few skewed faces. Due to a bit difficult geometry, it was the best result I could get. I am just wondering why the problems occurs after 9seconds of simulation. So the turbine already made 4-5 rotations. The other tip with fv-Schemes sounds interesting. Maybe you can find a problem in my fv-Schemes: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((muEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh; pcorr; alpha.water; } // ************************************************************************* // I will try to find out more about "bounding for gradU in fvSchemes" The simulation already runs with adjustableTimeStep and a maxCo of 0.95. Though I recongnized that mostly is possible to compute over these problematic time steps without an adjustableTimeStep and quite small timesteps of maybe 5e-5 or less. With adjustableTimeStep thats mostly not possible as it becomes less than 1e-100 with velocity magnitudes of 1e5 or even more. |
August 3, 2018, 03:11 |
#6 | |
Christian Jähnel
Rep Power: 9 |
Why would you say Co has to be less than 0.1 in VOF? Never heard of this criteria... Is'nt it just wasted computation time? |
August 3, 2018, 03:46 |
Honza Höll
Rep Power: 10 |
Hi, here is part of fvSchemes you can use for your case
gradSchemes { default Gauss linear; grad(U) cellLimited Gauss linear 1; } I recommend to you: 1. Use bounding for grad(U) and check mesh again (you can watch skewed cells in Paraview and improve mesh there) 2. Check BC again 3. Use lower Co Last edited by indy07cz; August 3, 2018 at 03:49. Reason: add info |
August 3, 2018, 05:19 |
Anton Kidess
Rep Power: 29 |
It is well known that the stability criterion for the standard VoF algorithm is much more severe for fine meshes than the Courant criterion for pressure-velocity coupling. Check the original paper of Brackbill, and for even more details the paper by Deshpande (everyone using interfoam should know these two papers).
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
