[mesh manipulation] Strange results after using refineMesh on radial 2D-Mesh
Old   December 24, 2013, 11:25
Default Strange results after using refineMesh on radial 2D-Mesh
Steve
Zarchias is on a distinguished road
Hello cfd-online,
I've been using refineMesh to refine a radial mesh (two concentric cirkels with cells radially extending in between) created in ICEM using an O-grid. The results are satisfactory, except when the cells are angled at approximately 45 degrees (and again at 135, 225 and 315).
At these angles refineMesh returns this strange division of instead of dividing it allong the edges it just divides it horizontally/vertically.
Something I've noticed is that this angle is right in the middle between my two global directions I've put in refineMeshDict. Upon changing these directions to a different orthogonal set, the strange behaviour shifts to a new position.
The settings in refineMeshDict are the following:
set c0;
coordinateSystem global;
globalCoeffs
tan1 (1 0 0);
tan2 (0 1 0);
patchLocalCoeffs
patch outside; // Normal direction is facenormal of zero'th face of patch
tan1 (1 0 0);
directions
tan1
tan2
useHexTopology true;
geometricCut false;
writeMesh false;
Has any of you encountered this before? And if so, how did you deal with it?
Thanks in advance!
Steve
Zarchias is offline   Reply With Quote
Old   October 30, 2018, 10:57
Lukas Fischer
lukasf is on a distinguished road
I am having the same issues 5 years later. Are there any ideas?
I think some information can be found here:
Refine a 3D-Mesh resulting in pure hex-mesh
The user "mturcios777" gives some interesting info.
Here refineMesh Problems: strange cells/cuts were added I am trying to solve a similiar issue.
lukasf is offline   Reply With Quote
openfoam, refinemesh, strange refinement
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Help: Strange unphysical results from mesh motion cjwhodge OpenFOAM Running, Solving & CFD 0 August 17, 2016 12:29
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine kbhamidipa3 FLUENT 0 November 30, 2012 15:52
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
