Flow through a cylinder gone wrong
Like Tree2Likes
  • 2 Post By clapointe
Old   February 19, 2019, 12:15
Unhappy Flow through a cylinder gone wrong
Vitor Heitor Cardoso
heitorvitorc is on a distinguished road
Hello Foamers,
I am very sorry if this question was already been answered, but I couldnt find any related solution. I'm very new in CFD in general, and I started working on a case for a laminar flow through a cylinder, and I'm using Gmsh to create the .geo file and then creating the mesh afterwards. The mesh seems ok, I can visualize the geometry in paraView and the checkmesh result seems ok. However when I run the simulation I get the same error concerning the boundary condition of the cylinderWalls. The message is written below:
Create time
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading transportProperties
Reading field p
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for cilynderWalls
file: /mnt/c/Users/heitorvitorc/Desktop/OpenFOAM/Projetos/teste_18_02_19/cylinder_case/0/p.boundaryField from line 25 to line 52.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/ubuntu/OpenFOAM/OpenFOAM-5.x/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
FOAM exiting
At first I thought it was a missed bracked or something related in the p file... But nothing seems to fix this issue.
The p file is below:
| \\ / O peration | Version: 5 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
top
type zeroGradient;
bottom
type zeroGradient;
cylinderWalls
type zeroGradient;
frontAndBack
type empty;
The U file seems fine, but since I am new to openFOAM, I might be doing something wrong, so the file is also below.
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (4e-6 0 0);
outlet
type zeroGradient;
top
type slip;
bottom
type slip;
cylinderWalls
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
I tried to change the boundary type in the boundary file inside the polymesh folder, but nothing seems to happen. The boundary file is below:
| \\ / O peration | Version: 5.x |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
frontAndBack
type empty;
physicalType patch;
nFaces 3610;
startFace 3515;
cilynderWalls
type wall;
physicalType patch;
nFaces 76;
startFace 7125;
bottom
type patch;
physicalType patch;
nFaces 38;
startFace 7201;
top
type patch;
physicalType patch;
nFaces 38;
startFace 7239;
inlet
type patch;
physicalType patch;
nFaces 19;
startFace 7277;
outlet
type patch;
physicalType patch;
nFaces 19;
startFace 7296;
In order to build a case like this, do I need to do something else? I'm searching everywhere but I simply cant overcome this issue. I'm using the icoFoam solver, but this info doesn't seems to be relevant, since it's not a solving problem.
heitorvitorc is offline   Reply With Quote
Old   February 19, 2019, 14:30
clapointe is on a distinguished road
Did you read the error? It is looking for a patch named "cilynderWalls" in your boundary conditions. Note the spelling.
Caelan
RobertHB and heitorvitorc like this.
clapointe is offline   Reply With Quote
cylinder, flow through cylinder, laminar flow, openfoam
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Flow past rotating cylinder: Problem with ForeCoeffs raf1111 OpenFOAM 1 December 16, 2013 09:45
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
