July 8, 2019, 11:33 |
Paraview - Calculation of Swirl Angle
Rep Power: 7 |
Swirl angle is a useful parameter to describe the inlet performance of a pump suction. It is defined as the ratio of tangential velocity to axial velocity.
Any expert here can explain how to calculate the swirl angle for a given plane in Paraview (possibly based on the calculator filter)? Is it necessary to do the calculation based on the vorticity results, or just the velocity results are used? Thanks a lot. |
July 13, 2019, 05:41 |
Rep Power: 7 |
Any expert here can advise?
Is it appropriate to use the surface integral of vorticity (curl) to find the average tangential velocity? |
November 3, 2021, 02:58 |
Munaf
Rep Power: 6 |
Did you manage to find an answer to this please
[General] Wall Shear Stress Calculation with Paraview | ahmet | ParaView | 1 | June 20, 2019 18:57 |
Resultant swirl angle | OOTB | Main CFD Forum | 0 | October 21, 2016 05:23 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
[OpenFOAM] Flux Calculation in ParaView | dinksy | ParaView | 0 | October 17, 2012 00:33 |
