Difference in the predicted locations of hydraulic jump (kOmegaSSTDDES vs kOmegaSST)
Old   November 20, 2019, 06:26
Default Difference in the predicted locations of hydraulic jump (kOmegaSSTDDES vs kOmegaSST)
foamF is on a distinguished road
I just did a simulation of hydraulic jump (2D case) to compare two turbulence models: RANS based kOmegaSST and DES based kOmegaSSTDDES. The simulation result is put in: https://youtu.be/52YP5D38pfc
Same grids and same boundary conditions in both cases.
The 2D case is physically incorrect to simulate turbulence which is 3D in nature, but it still offers some clues on turbulence modelling.
The location of the hydraulic jump predicted by the kOmegaSST model is much farther from the inlet than that of kOmegaSSTDDES. Can someone here explain the locations of the hydraulic jump predicted by both turbulence models?
foamF is offline   Reply With Quote
Hydraulic Jump with St Venant Equations IbizaFR Main CFD Forum 0 January 28, 2019 13:00
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
difference between kOmegaSST (OF-1.7.x) and kOmegaSST_lowRe (OF-1.6-ext) florian_krause OpenFOAM 3 May 16, 2012 09:02
hydraulic jump thomi tomsen Main CFD Forum 0 March 22, 2001 07:50
HYDRAULIC JUMP Valdemir G. Ferreira Main CFD Forum 3 October 29, 1999 09:35
