How to adjust the supply temperature based on a probe reading in OpenFOAM?
Old   June 23, 2020, 09:58
Default How to adjust the supply temperature based on a probe reading in OpenFOAM?
ijaz fazil
er_ijaz is on a distinguished road
Hi I'm working on HVAC modelling, I need to adjust the supply temperature based on a probe reading or avg measurement over a patch. The supply temperature need to be adjusted every iteration (for steady state) or time step (for transient analyses).
Can I who how to do it in OpenFOAM?
er_ijaz is offline   Reply With Quote
Old   July 1, 2020, 18:43
Anup Singh
Anup Singh is on a distinguished road
If its something static then you can simply write a file and read it in your BC otherwise if its dynamic in nature you can simply implement the changes to your boundary patch in your solver or write a new BC which reads the data as per your need.
Anup Singh is offline   Reply With Quote
Old   July 3, 2020, 09:38
ijaz fazil
Dear Anup Singh
Thanks for your reply.
buoyanboussinesqsimple, buoyantboussinesqpimple, buoyantpimplefoam, buoyantsimplefoam, openfoam
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Overwriting Temperature in OpenFoam IvanaS OpenFOAM Programming & Development 6 June 25, 2013 07:34
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
incorrect temperature in pressure based solution Kian FLUENT 1 July 6, 2009 05:59
