Solid Chemistry Models removed in OpenFOAM 8? |
February 1, 2021, 11:48 |
Rep Power: 7 |
Hi everyone,
it seems like the solid chemistry models, which existed up to OpenFOAM 7, are no longer present in OpenFOAM 8. Does anyone know more about it? Why was it removed? Or is it just renamed and moved to another location? I couldn't find anything about it in the release notes either. |
February 1, 2021, 12:22 |
Ran
Rep Power: 9 |
What is `Solid Chemistry Models`?
Is this a transportProperties, a momentumTransport, a volScalarField or a solver?
Yours in CFD, Ran |
February 1, 2021, 14:57 |
Rep Power: 7 |
It's a thermophysical model, which provided the possibility of implementing reactions for solid regions. See code of OpenFOAM 7:
https://cpp.openfoam.org/v7/solidChemistryModel_8H.html |
February 2, 2021, 04:15 |
Utkan Caliskan
Rep Power: 11 |
You may check out the description of this commit on why it's removed.
https://github.com/OpenFOAM/OpenFOAM...82e345d1e5b9a7 |
February 2, 2021, 04:27 |
Rep Power: 7 |
Alright. Thanks for your help :-)
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Solid PYROLYSIS + MOISTURE drying --> Possible in OpenFOAM? | Kummi | OpenFOAM | 3 | August 13, 2019 00:37 |
Solid Energy models | Rj33320 | STAR-CCM+ | 1 | August 16, 2018 16:25 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
