Lagrangian Particle OpenFOAM
Old   May 30, 2022, 10:06
Default Lagrangian Particle OpenFOAM
Mid_Night is on a distinguished road
Hello. I made a simulation of the motion of Lagrangian particles using the "particleFoam" solver. Each particle was counted separately and then I put them on one graph. It seems to me that I got the wrong trajectories because the particles practically do not rise along the "x" axis. What could be the mistake?
P,S, At the beginning I counted the inviscid gas using "rhoCentralFoam". Then I took the velocity and density distribution and worked with the "particleFoam" solver.
Mid_Night is offline   Reply With Quote
Old   June 9, 2022, 08:13
Josh Williams
joshwilliams is on a distinguished road
Have you tried running the simulation with "coupled" as true? I think this is the issue.
joshwilliams is offline   Reply With Quote
Old   June 13, 2022, 13:43
thanks for the reply. I consulted with some people and realized that I got a fairly correct result. And what is the "coupled" setting. And what it affects. When I ran the simulation with "true" I didn't get the change.
lagrangian particle, openfoam, particlefoam, rhocentralfoam
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches Armin.Sh OpenFOAM Running, Solving & CFD 7 March 28, 2021 22:33
Lagrangian data - particle velocity post processing Ake OpenFOAM Post-Processing 12 August 16, 2020 07:54
Lagrangian Particle, first particle integration step wrong dt and age? Sverre Magnus OpenFOAM Programming & Development 0 February 13, 2020 05:39
Post processing of Lagrangian particle field marialhm OpenFOAM Post-Processing 0 October 8, 2017 22:02
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
