June 24, 2023, 12:12 |
Openfoam meshing snappy hex mesh
West Midlands
Rep Power: 3 |
My mesh is stuck in iteration 0 as follows, and does not move beyond this, what could be the reason for this?
Edge intersection testing: Number of edges : 1520000 Number of edges to retest : 40000 Number of intersected edges : 53747 Decomposition method none [1] Refinement phase ---------------- Found point (0 0 0) in cell 0 on processor 0 Feature refinement iteration 0 |
June 26, 2023, 05:38 |
M
Rep Power: 12 |
There is very little information here, you might want to check out Guide: How to ask a question on the forums
What your post does tell me, is that you are using (0 0 0) as the locationInMesh, which is against several recommendations. The locationInMesh should never coincide with a face or a node during all meshing phases. Round values or integers are usually prone to hitting such an entity, depending on the geometry. So maybe using e.g. (0.0012 0.012 -0.021) already helps. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 07:21 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 00:14 |
