Launching error with paraview 3.4.0
Old   July 3, 2009, 05:54
Default Launching error with paraview 3.4.0
aaurouss is on a distinguished road
I installed paraview on Windows XP, and I there is an error when lauching
The "MSVCR71.dll" file is missing..
Has some already had this problem before ?
Thanks
aaurouss is offline   Reply With Quote
Old   July 3, 2009, 06:01
dipling is on a distinguished road
no, but why not download it
http://www.google.de/search?hl=de&q=...&meta=&aq=f&oq=
And put it in the system or system32 dir of XP ?
dipling is offline   Reply With Quote
Old   July 3, 2009, 10:55
Thanks, it works.
But now I have another problem:
I run the OpenFoam tutorials on a Linux system and use Paraview with Windows. I can mount the Linux directory to read the tutorial data from Windows. But i can't open the .foam files, i don't find them ...It seems that the visualization with paraview on windows is different than using it under Linux...
Has anyone know smthg about that ?
Old   July 6, 2009, 17:29
What do u mean with .foam files ? But i think u solved the problem now
Old   July 7, 2009, 09:01
It's possible to generate .foam files (which are called 'dummy files' in the user guide).
It's necessary when you need to open the OF case manually with ParaView. When launching the case with Linux ParaView, the OF script paraFoam generates such a file, "gathering" the datas from the different files and sub-directories. But this file isn't available to open so we need to create one.
Old   July 7, 2009, 09:03
And yes my problem is solved now
Thanks
Old   July 16, 2009, 11:29
Antoine ducoin
actone is on a distinguished road
hello everyone,
i have the same problem. Can you create .foam files using windows?
actone is offline   Reply With Quote
Old   July 16, 2009, 11:37
If you have the same problem, then I may have an answer now. You have to generate .VTK files that are readable by paraView using the command "foamToVTK" in the case directory.
Old   July 16, 2009, 12:00
Antoine ducoin
Thanks for your very fast answer!
I tried this, but there is still a problem, i can see the vtk file in the "pipeline browser" but i have an error when i want to apply:
ERROR: In C:\tmp\OpenFOAM-1.5\3rdparty\ParaView-3.4.0\VTK\IO\vtkUnstructuredGridReader.cxx, line 350 vtkUnstructuredGridReader (0x1f50d738): Unrecognized keyword: o>€$Í<£w£:o>‚í< :«:o>„h<œþ¯:o>†)<™¢z:o>ˆs´<–$Ë:o>Š“[<’„t:o>Œéi<Ž¿¼:o>v½<ŠÕ™:o>‘Ü@<†Äw:o>”zá<‚ ŠÏ:o>u
but maybe that is a very basic problem since i just installed Openfoam
Old   July 20, 2009, 05:23
Antoine ducoin
it seems that it comes from the foamtovtk command on windows, because i solve my problem, it propely works. I also tried to solve on a linux computer then do foamtovtk on linux and transfer it on my mindows and it works.
any idea?
Old   July 20, 2009, 08:51
Bon je vais répondre en Anglais, par politesse pour ceux qui veulent lire le post !
Your methodi is the same I'm using, and it seems to be working properly .
So the problem is solved, isn't it ?
Bon courage
Old   July 20, 2009, 09:02
Antoine ducoin
the problem is fixed by typing: foamtovtk -ascii ...
thank you
Old   August 4, 2009, 02:04
padhu
padmanathan is on a distinguished road
hi,
i'm also facing the same problem, can you tell me where we have to change foamtovtk-ascii?
thanks & regards
thank you
padmanathan is offline   Reply With Quote
Old   August 4, 2009, 10:44
Antoine ducoin
after the blockmesh command, type foamtovtk -ascii, into the same folder. Then it will create a vtk folder with .vtk files inside, that you will be able to open with paraview.
does it works?
Old   August 5, 2009, 00:57
padhu
hi Antoin,
thanks for your reply, it is working fine for me.
what i tried is, though i'm using windows OpenFoam, after giving blockmesh, by right clicking on foamToVTK and in customize write as
"foamToVTK -ascii" and close. then, in foamToVTK right click and run start custom.
that's it.
thanks & regards,
padhu
[OpenFOAM] Paraview in Prallel (server-client) prapanj ParaView 11 September 24, 2010 07:12
[OpenFOAM] ParaView 340 experience Does not show animation eno ParaView 10 November 14, 2008 12:38
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
[OpenFOAM] Animating Lagrangian Particles in ParaView xiao ParaView 4 April 8, 2008 02:24
[OpenFOAM] ParaView patch visualisation error in Development version philippose ParaView 17 March 26, 2007 06:45
